philco 42-321 dial cord diagram
I am not able to find the dial cord diagram for the Philco 42-321. I've checked Sams Dial stringer. Not there.
All help is welcomed
Thanks Again
ABV
The 42-322 is the same set electrically as the 42-321 so perhaps the dial stringing is the same also.  There are some pics and a hand drawn dial string diagram in my notes. I no longer own the set. (This was the first set I worked on so took a lot of notes.)
http://home.ptd.net/~coraor/documents/Ph...ration.pdf
Bob,
I did look for closer models you suggested. I was not able to find it directly.
What I did do was go back to Sams radio cord stringing pdf file and started to just look through many
cord diagrams that were close to this radio model PHILCO 42-321. The position of the tuner wheel, the knob and the guide wheels.
I found one that is close. ( drawing #343) I strung it out and it works.
This pdf file should be helpful for others.
Thank You for your response Icon_angel
ABV
