Threads: 19
City: Rock Hall
State, Province, Country: MD
Just got finished putting back together this project.
Saw that nothing has been shown on this model on the Phorum.
So here it is, some new caps, new leads to IF can, put all
Philco vac tubes in plus a couple of other things.
See if you can find a part that I will be changing.
An maybe some leads of what the right one looks like or how to get one.
Image(s)
(This post was last modified: 01-18-2020, 05:35 PM by
truePhilco .)
Threads: 25
City: Louisville, KY
Well, let's hope you're gonna change ALL of those paper capacitors!,
. . But I guess you're referring to that Sanyo loudspeaker.
Threads: 19
City: Rock Hall
No, sorry sir that is not what caught my eye.
"spot it in the second picture".
and take a look at a link to see what things
happen in 1941.
Threads: 270
If you are looking for a source for parts then this
http://www.tuberadios.com/capacitors/ is a good one. Most of the time I'll get a sack of 25 caps of a given value not so much the onezy or twozy. If you are a stickler you can restuff the foil/paper caps using some brown colored hot glue in the ends. You may want to grab some wire too as your set has the old failing rubber coated stuff. While you are replacing the caps it's a good time to measure the resistors and replace the bad wires. I typically will replace all the rubber wire that carries the hv some do all of the wire but I'm lazy.
Now I think I've got it!
(This post was last modified: 01-18-2020, 06:45 PM by
Radioroslyn .)
Threads: 12
City: Monroeville, PA
How about the Grill cloth?
Threads: 19
City: Rock Hall
Your right it has been replaced, but there
is something that should be replace. I gave a clue
that its seen in the second picture, new clue remember
I'm true Philco.
Threads: 13
City: Greenwood
State, Province, Country: Delaware
Threads: 5
City: manhattan beach, CA
The wires to the dial light? They're in bad shape.
Threads: 19
City: Rock Hall
I'm glad you spotted it, I was beginning to
think it was suppose to be there, not
I was shocked to see it in there.
my paper said it should be part #36-1510,
dose anyone have a pic of it, not finding it
on the internet.
Wa3uay, maybe I need to do that kind
of game again but offer a prize, that would be fun
on the Phorum,
Threads: 12
No wonder I didn't see it. I have been looking at the 3rd picture. LOL.
Threads: 114
City: Sneedville, TN
Jake spotted it way back near the beginning, and I quote, "... But I guess you're referring to that Sanyo loudspeaker. "
Threads: 25
"Jake spotted it way back near the beginning, and I quote, "... But I guess you're referring to that Sanyo loudspeaker. "
Threads: 13
City: Greenwood
Oh well, easy come, easy go
Threads: 5
It was a lot easier than I thought. Your reference to 1941 threw me for a loop. I thought this radio may have had its shortwave disabled but the first photo showed it had all of the coils in place so that wasn't it.
Looks like this model has three of these dial lights. The wires to the lamp holders should be easy to unsolder and replace.
Hello,
I am in need of a schematic for this radio. Mine has the three separate circular tube shields and a shadow me...dconant — 08:06 AM
Hello Roy,
sincerely Richardradiorich — 12:45 AM
Richard,
Had grabbed it already but thank you just the same. I find myself wanting to find some way to block out the...glyphmon — 12:03 AM
Hello roy,
Sincerely Richardradiorich — 11:54 PM
Richard,
The Silvertone 2014 also is a transformerless set, so I am incorporating a 1:1 600 ohm audio isolation transfo...glyphmon — 11:37 PM
Did an alignment today which was interesting. IF alignment went great, almost all was already spot-on. Adjusting on th...glyphmon — 11:35 PM
