Model 20 Winding data needed
Anybody got data for the rf and detector coils? Has any rewound the speaker field coil? Size wire?
Tnx!
I have a parts chassis, I may have the rf and detector coils.
Bob T.
Tnx for offer! I ended up counting the turns myself. Seems that just the primaries where open and it's a fairly small winding about 50 turns. All coils now are ok. Have yet to rebuild the filter bank and then I can take her for a spin! Will keep you in mind if I need any bits or pieces. Come to think of it do you have a good driver transformer? The one on my model 21 has an open primary.
I will check it out and get back to you.
If good, yours for the shipping.
Bob T.
Wilmington, NC
I've never tried to rewind a field coil.
If you have a Harbor Freight store near you, I would suggest you buy a micrometer from them. Then you can determine the size of the wire by measuring the original, and using a wire table which can be found in many old radio/electronics textbooks (and probably online as well), and convert the diameter to the proper wire gauge.
I picked one up a couple years ago to assist me in rewinding coils.
Oh, I looked in my notebook where I keep my notes on various Philco coils, and I don't have any data on the 20 coils so it appears I've never rewound any.
[split] New member...
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
There are currently 874 online users. [Complete List]
» 1 Member(s) | 873 Guest(s)
