recently acquired 41-280
Glad to report to you all that this radio is working on all 3 bands. A couple of issues remain....2 of 5 dial lamps are not lighting and I have to figure out the dial stringing. Then I will have to decide how much to work on my cabinet. Not bad, but can be helped a little I think when warm weather comes.
Thanks to all for your help.
Art Hoch
Congratulations! Icon_smile Icon_thumbup
Thanks Ron. Always a good feeling to bring the dead back to life! Any body know where the "pushbutton" lamp wire connects underneath the chassis Icon_confused: Impossible to see due to the crowded area where it comes through the deck.
Ok.... In the fourth year of the war, I still decided to return to an active hobby. For more than three years, I did not...RadioSvit — 10:43 AM
Philco 37-116 Cabinet Repair
You'll probably have to get quite a large amount of wax filler, those are some big gaps, and both sides. Nice summer pr...RodB — 10:38 AM
Hello everyone. I completely agree with Richard and Dan - in this case, without replacing the veneer, only a wax filler ...RadioSvit — 10:07 AM
I have used Timber Mate Timber mate is a grain filler  . You can get it in different colors,so it will be close to...Dan Walker — 09:51 AM
Help with Supreme 599
The 300 ohm line adjustment is used to set the primary of the transformer to a nominal voltage for any line voltage from...DaleHCook — 09:22 AM
I think Arran is correct about the substrate expansion. I'm going to give the colored wax a try.dconant — 08:11 AM
Hello Guys, What I would do is get  colors of wax filler and fill in the void ! Sincerely Richardradiorich — 12:41 AM
It looks to me like the structure under the veneer may have expanded from humidity cracking the veneer on the surface. W...Arran — 09:42 PM
Iam only getting 4vac out of the tranny For the 80 filament. The line rheostat Looks fine and the tranny is getting 11...daveone23 — 08:45 PM
Rogers Majestic R-646
Transformers rewind? It's very easy! If you don't have round eyes  8-) Vlad95 — 01:55 PM
There are currently 1176 online users. [Complete List]
» 3 Member(s) | 1173 Guest(s)
