phase inverter question
As I continue my first journey through capacitor replacement (4 done so far!), I'm learning about the various circuits.
Would the Phorum wisdom please help me understand the paths in and out of this 7AF7 (46-1209)?  I think ...
... audio comes into the left-side grid (pin 4); it goes out the left-side cathode (pin 2) and, inverted, out the left-side plate (pin 3); these go into their respective 6V6s.
Am I on the right track?
Yes, you are correct. This type of phase inverter is a cathode follower. The plate load resistor and the cathode resistor are close in value so the signal level will be almost the same. This circuit will be very sensitive to age related drifting of the 2 resistors.
Woo-hoo! Thank you, Rod.
Just to confirm: the two resistors in question are 86 and 87? They measure 372k and 439k. Should I replace them?
Does the right-side triode handle the phono signal? If so, does it also do the phase inversion dance?
The resistors in the phase inverter are 78+79 and 80. The right side triode is a preamp for the phono Input. It's output runs off the diagram, probably to a mode switch then feeds the phase inverter.
Yes, replace 86 and 87, they are way out of tolerance.
Many thanks!!
Need Help to ID this radio 11 tube Philco
If you want a radio that's difficult to work on, get a 37-620. The one side of the chassis is packed pretty tightly and ...Greg — 07:29 PM
Philco 16 is not intimidating at all. Despite being an 11-tuber. 37-116 is indeed intimidating. 16 has good space unde...morzh — 04:11 PM
48-482 rear panel help
Thanks for the responses Gary and Bob. I'm a little surprised that there's no back panel - although I know older Philco'...keithchip — 04:09 PM
Gary is correct, there was not a rear panel on the 48-482. I restored one of those and its a great sounding radio that ...klondike98 — 03:24 PM
A little light positivity in our feed... To nostalgic retro music... With English subtitles My new video on the contin...RadioSvit — 02:14 PM
My Philco 37-116 Restore
Ron and Mike I mentioned a 2 meg resistor not on the schematic. I stumbled on a changes note in Riders that mentioned th...dconant — 12:02 PM
Here you go: Your the code 125Radioroslyn — 11:12 AM
Hi Ron, Thanks for the input. I think I'm going to call it good enough. It does seem weird I can usually dial in othe...dconant — 08:01 AM
Welcome, the radio looks intimating 11 tubes, wish you well.Jimradio — 07:49 AM
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
There are currently 340 online users. [Complete List]
» 2 Member(s) | 338 Guest(s)
