Threads: 270
Correct. It's the small most outer winding. It's also the one that fails via decay. It is there to create feedback to cause the oscillator to run. A bit like a regenerative receiver w/o the fones
Now I think I've got it!
(This post was last modified: 09-10-2020, 08:11 AM by Radioroslyn.)
Threads: 1
City: Corrales
State, Province, Country: NM
Terry,
Interesting. Very helpful. I’ll get back into the Philco in a day or two. I’ll let everyone know how it goes. Working on an AA6 now...finally recapping it.
R
Threads: 55
City: Roseville, MN
Yes, Terry, that's correct. I missed that. It's an oscillator in a tank circuit, no wonder it's touchy. I would also look at the cathode bypass cap. I once fixed an amplifier tremolo circuit that had a bad cathode bypass.
Threads: 270
It is kind of a primitive circuit. The older sets (70) used two tubes to perform the mixing duties. Seems like there would be some interaction between osc frequency and the peak adjustment of the 1st IF. The 36 tube (tetrode) needs a suppresser grid but such was the technology in 1932. The generation sets used the 39/44 a full fledged pentode.
(This post was last modified: 09-10-2020, 10:36 AM by Radioroslyn.)
Threads: 50
City: Allendale, MI
For grins and giggles, I pulled my 71 off the shelf and looked at the oscillator signal on the scope taking the signal at the cathode. Beautiful sign wave at 1500 kc. Amplitude went down as I tuned lower. Plus the shape of the waveform degraded severely. The cathode resistor is original and measures 11k. I paralleled another resistor to bring the cathode resistor down to about 8.4 k. The cathode waveform on the low end of the dial increased substantially, though still distorted. At the high end of the dial, the waveform was good but with slightly less amplitude than without the resistor. I left it in the circuit cuz the radio seems work a bit better on the low end of the dial.
(This post was last modified: 09-10-2020, 05:11 PM by rfeenstra.)
Threads: 1
City: Corrales
Fun. Good to know. My alleged 15K resistor (as marked) measured 12.5K, and ironically, I, too used a parallel resistor and ended up with 8.4K. My LO was then good to about a receive frequency of 600 khz before all reception stopped at lower frequencies, because the LO quit. But right now, the LO has quit totally (again) and the receiver is dead everywhere.
I sometimes wonder how the osc tube would respond to higher B+.
Anyway, I’ll get back to this sad little oscillator this weekend.
R
Threads: 50
City: Allendale, MI
I did have to rewind the oscillator coil on my 71.
Threads: 1
City: Corrales
Was it fully open, or intermittent? My osc comes and goes at will. Since I’ve not pulled mine out, how many turns does it have? And what insulating material did you wind it on (separating the windings)?
Threads: 50
City: Allendale, MI
I don't remember. I probably looked at it and saw the typical green corrosion. If it wasn't bad yet, it would have been in the future. So I rewound it. Any Philco with the nitrocellulose insulation is suspect.
Threads: 50
City: Allendale, MI
Here is a before and after pic. The coil does not look bad as i don't see any green. But I probably figured it would go bad eventually.
After the original winding was removed, the coil was baked and then sealed with lacquer.
Threads: 1
City: Corrales
An update. The intermittent local oscillator refuses to quit, as usual, now that it’s on the workbench. I got it running by the usual ”shock excitation” method by touching the grid of the 36 osc/mixer with a short test lead. And now, it won’t quit. Plays for hours. When it finally does die, again, I’ll check voltages. But running properly, it has 90 Volts on the screen and about 260 on the plate...that should be more than enough to keep it oscillating.
Richard
(This post was last modified: 09-14-2020, 07:10 PM by WB5NEN.)
Threads: 270
Is the feedback winding rewound? Same direction as original and wire ga around 38ga?
Threads: 1
City: Corrales
Terry,
I have not rewound the feedback coil, because it shows good continuity. I have, however, thought about rewinding it just to get a few extra turns in a (probably foolish) attempt to provide more feedback. Once it quits again, and if I find voltages are still what they should be on the tube, I will also check the coil for continuity.
But if this sounds like I’m taking the wrong path, let me know!
Richard
Threads: 1
City: Corrales
Update. I need my workbench cleared from the Model 71 woes. The 71 is still playing, the LO is (for the moment) still oscillating, and I am poor at troubleshooting a working circuit. I put the 71 back in the cabinet, put it in its permanent place, it’s still working, so I will move on to another project (replacing a busted belt on a console Zenith). Thanks to everyone. Sorry for the lack of resolution.
Richard
There are currently 1613 online users. [Complete List] » 1 Member(s) | 1612 Guest(s)
