What model is this? Found one locally. 116B?
Dial/speaker does not add up.
Not even close to 116B, though the year is the same.
It is a 630.
We could look at the grill.
But you might want to show the chassis also.
That's the only two pics posted, he says it is that, but the 116b shows difference. Says it powers up, no reception, what would it be worth?
(by the look of the cabinet the same one was used in 635).
Worth? Depends. If the speaker is good - $70, +/- 10 bucks. If it is 630. Do not know what 635 would be. Probably less.
If it were 116B, which it is absolutely not (it is a very different and much larger unit) it would get above $200 if in decent shape.
Thanks, I think that's it, 116b 11 tubes vs 6 in this one, never heard either, guess the 116b kills it. Is this one worth collecting or just so so?
It is a good radio. I have a 620, one step down, still good. I actually like the 1936 radios.
As for worth.....the beauty is in the eye of the beholder - if you like it, it is worth collecting. My personal criterion.
For example, I am not a fan of the 610 look, to chubby for me. So I do not have it.
Dial bezel is on upside down...
Yeah...I was wondering myself where the heck the Shadowgraph window was......
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
There are currently 1124 online users. [Complete List]
» 1 Member(s) | 1123 Guest(s)
