Atwater Kent 708
I missed your earlier question:
Heat will "reactivate" (melt) hide glue. Modern wood glue will not stick well to old hide glue. If you ate going to use Elmers, I would scrape away as much hide glue as possible with a razor knife.
Thanks Russ. The delamination was on the bottom board, just at the edge. I used modern hide glue. Probably doesn't stick much better than other wood glues to old hide glue, but it is holding for now.
Ready for final coats of lacquer, but have to wait for decals from Radio Daze.  I decided to assemble and use until then.  The grille cloth is original.  They didn't put in on real straight! I think I've decided that this is my favorite Cathedral design.  The radio isn't as good as a couple of the Philco's  I own, but I like the design.
Mahhvelouusss...............looks fine, enjoy.
Looking good  Icon_thumbup
I've found that AK grille cloth seems to hold up better than many of the others.  I've found many AK sets where the finish was beat and the cloth faded but still intact.
Quote:I think I've decided that this is my favorite Cathedral design
I remember pouring over my old collecting bible, "A Flick Of The Switch" by Morgan E. McMahon, and looking at these three styles of AK cathedrals.  Eventually, and somewhat unintentionally, I slowly acquired all three of these.  The 708 was first followed a few years later by the 217 that promptly got buried and forgotten on a garage shelf.  When I eventually rediscovered it 3 or 4 years ago I had developed a deeper appreciation for this "squatty cathedral" design and decided I needed the 246 to round out the set.  Lo-and-behold at Kutztown that fall a friend brought a model 246 and made me a deal I couldn't refuse.   While the 708 is the more deluxe of the three, the 246 and 217 have grille and inlays that make them interesting in their own right.
Arthur Atwater Kent went to Worcester Polytechnic Institute here in Massachusetts, had a plant in Worcester making motors. I have gone by a home he owned in Kennebunport Maine in a boat, "Waters Edge" it was once owned by the Vanderbilts. Very interesting guy, quite a New England connection, and many fine radios........
Finished!  Here is the final product.  After a couple of weeks, I'll give it a coat of wax.  Plus, I need to put the proper feet under it.  They are the same as what Philco used and Steve Davis is making.  Again, one of my favorite cabinets in my cathedral collection.
Absolutely beautiful! Great job!!
That turned out great, it is a beauty Icon_thumbup
I think Atwater Kent made some of the prettiest cathedral designs with the 80 & 90 series, but I'll agree this thanks right up there with any of them.
Thank you, guys! It has been moved out of the shop to a more permanent location where it will be played regularly. It sounds pretty good. With the dial being as small as it is, it can be a bit difficult to center a station, especially on the short wave bands. My Philco 16B performs better.
That came out beautiful! I’ve not seen one of these locally. AK sets seem to hit or miss.
Tony
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
Refinishing Ideas
My 37-116 code 121 is the best sounding radio i have...a daily driver. Since we are talking about "changes". ...poulsbobill — 07:18 PM
Hello, I finally got brave enough to take the cans off the Expander Unit. Got the grid cap wires replaced and back toget...dconant — 06:50 PM
I got into the first AM IF can today, and found its mica was cracked. Amazing that it was still working. This one makes ...EdHolland — 06:10 PM
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
There are currently 718 online users. [Complete List]
» 1 Member(s) | 717 Guest(s)
