Thalia & Melpomene
Been somewhat busy - -
Thalia & Melpomene
The confusing Crosley Fivers.
Russ
Thanks for sharing those with us.
That is one heck of a 25hz transformer on the 555-5 chassis!
How about that. Until now I did not know the muses had names. When I saw "Thalia" I first thought of Thalia Menninger, a character in the first two seasons of Dobie Gillis played by Tuesday Weld.
Speaking of Dobie Gillis -
https://ronsradios.com/2020/11/18/rememb...is-packer/
there is Kalliopa, Klio, Melpomena, Terpsihora.....fogot others. The lates one is responsible for dancing.
Not sure I spelled them correct - I transliterated from Russian versions.
With Melpomena it was easy as the phrase "a server of Melpomene" was used for theater actors as a metonymy. Somehow it was used for all actors, not just tragic ones. And Talia was not.
Need Help to ID this radio 11 tube Philco
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
1.7-3.9 %, a modified Sine wave inverter is around 25%. Most generators from big box stores run 10% at a 50% load. What ...David — 04:06 PM
I am having a heck of a time doing the alignment on the AM band. I can't seem to dial in the 1500 KC oscillator. I can h...dconant — 03:35 PM
David - I think I understand but what units are you discussing (Low of 1.7, high of 3.9)? Budget constraints for Ham ...EdHolland — 01:43 PM
You're doing great. I wish I could be more involved, but my mind is right now preoccupied with the reason I am here in ...morzh — 12:21 PM
Hope you guys are still with me. I have moved on to the alignment. I completed the IF alignment which was pretty muc...dconant — 10:47 AM
There are currently 728 online users. [Complete List]
» 1 Member(s) | 727 Guest(s)
