Philco Q-1710?
Hi there,
Recently purchased a Philco Q-1710. I’m trying to find out the year it was made. I’ve been trying to research online but I cannot find anything! Does anyone have any info that they could share about this model?
Thanks!
It helps a lot if you post a photo. I'm guessing this might be a 1960s radio.
Hi there! I am having difficulty including a photo in my post. From what I’ve found, other Q models came out in the 60’s so I was thinking the same. I will continue trying to add a photo.
Hi and welcome,
Your Q 1710 dates from 1967 and is listed in Sam's Photofact #913-7.
GL w/your project!
I've started looking into the very weak and garbled reception in the set (I have the HS-62A version of the chassis seen ...klondike98 — 12:00 AM
Those last photos were not very good,so I  used one of my other cameras. This is more like the true colors of the radio....Dan Walker — 10:48 PM
If you look closely at the paper wax capacitors they probably have something like "outside foil" near the blac...RodB — 10:41 PM
Hello Dan, That really turned out very nice and I also like that color it is not to dark . I Have General Electric m...radiorich — 08:50 PM
Table radio 51C or 52C?
The model 51 and 52 are identical mechanically, I'm not sure what may have been changed between the two chassis but one ...Arran — 08:18 PM
Well today I  installed the grill cloth board and the speaker.  The speaker must weigh 20 pounds by itself. I put the c...Dan Walker — 08:10 PM
Unidentified Philco Bakelite
It's a British Philco, likely from the early 1950s. It has a very common layout for British sets starting in the post wa...Arran — 08:02 PM
I suggest you take that look under the hood eventually. Makes little sense to try to figure things out without looking ...morzh — 07:03 PM
Possibly a UK radio. I make this presumption based on the Long Wave band. A photo of the back available? Take care, -...GarySP — 06:18 PM
Morzh There are only 7 wires coming off the transformer. 3 for B+, 2 for 115 in and 2 for 5V to the 80. Maybe there i...antiqueradionut — 05:36 PM
There are currently 370 online users. [Complete List]
» 1 Member(s) | 369 Guest(s)
