Motorola 77FM..
Started to work on this.. All recapped . Getting lots of stations on AM.. But when switch to FM all I get is a Hum. Hum gets loader with volume..
Where do I start? Have not worked on FM circuits in a long time.. Even if I inject a FM signal I still get nothing..
Skip
You can start with the 2 tubes that are used in handling FM, 12AT7 FM converter and 19T8 Detector. If they are OK then S2 the AM/FM switch switches B+ to the 12AT7 converter. You should see plate voltages on that tube when in FM. Measure the voltages and compare to voltage chart. You should see a negative voltage at the FM discriminator circuit when feeding a 4.3 MHz carrier in the FM section. The voltage should vary with signal strength. That should keep you busy for a short while. GL.
Ok Replaced the 12AT7 and the 12BE6.. FM started to work many stations..
So not sure which one fixed it.. and really do not care.. But both tubes were tested in tube tester and showed good..
Just goes to show.. the real test in in circuit..
Skip
The 12BE6 is used as the mixer for AM so it's probably the 12AT7. Yes, at that frequency a tube tester is a marginal instrument.
These  tubes hate me 12AT7, 12DT8, 19T8, 19V8,  always good to have a few extra! David
There are currently 2016 online users. [Complete List]
» 1 Member(s) | 2015 Guest(s)
