Philco fm radios
Are these more difficult to restore. Interested in finding out your experience with them and if you would recommend them for a newbie to tackle. A couple on eBay now that I am looking at.
Thanks
Chris
I am working on one, 46-1213.
I am in the process of recapping. Will let you know once I am into the alignment.
I do not think it is very difficult. Same bunch of resistors, capacitors, coils and tubes.
Generally, FM uses the same circuits as AM from the detector back to the speaker. Get the AM working, then monitor the FM discriminator cap voltage, which is the small electrolytic at the FM discriminator diode. It's the AGC, equivalent to the AVC in AM. Send a carrier signal at the IF frequency to the FM front end and you should see the AGC voltage vary with signal strength. FM will use a separate set of IF transformers, often mounted in the same can as the AM, but the same tubes as AM. The band switch will select which transformer to use. Often the switch will cause problems.
Here's a YouTube link to a real good explanation of FM signal path and a simple way of doing the alignment: https://youtu.be/fNkDuEJjXm0
David - I think I understand but what units are you discussing (Low of 1.7, high of 3.9)? Budget constraints for Ham ...EdHolland — 01:43 PM
My Philco 37-116 Restore
You're doing great. I wish I could be more involved, but my mind is right now preoccupied with the reason I am here in ...morzh — 12:21 PM
Hope you guys are still with me. I have moved on to the alignment. I completed the IF alignment which was pretty muc...dconant — 10:47 AM
Hello MrFixr55, Thank you for taking the time to explain. I measured 50 volts where you say. Today the 370 volts at ...dconant — 12:51 PM
Oh that sucks. It’s something easily overlooked. Hopefully it’s nothing more than a resistor! Ron462ron — 08:08 AM
Just confirmed that you are correct. It’s the function generator. I connected the signal output probe to one of the inpu...jrblasde — 07:52 AM
Ouch, you may be right. Yes, it is solid state. It’s the signal output of my oscilloscope. May be time to crack that ...jrblasde — 07:27 AM
If you didn’t put a DC blocking cap between the signal generator probe and the plate of the 1st IF it’s possible you ble...462ron — 07:07 AM
Hi DConnant, The reason why C127 is isolated from ground is because sets of this vintage did not have the center tap...MrFixr55 — 01:07 AM
The shield is on the 6H6. It was, in fact, a missing jumper to connect the main chassis ground to the RF chassis grou...jrblasde — 10:58 PM
There are currently 1024 online users. [Complete List]
» 1 Member(s) | 1023 Guest(s)
