Model 37-3630A Candohm Replacement (US 37-630)
I am replacing the candohm in the picture attached (#61).
In the Philco Phorum I read that the 202 is ohm 20W, 8 ohm is 2 W and the 35 ohm is 5W.  I am considering using Vitrious Enamel Power resistors but the values are not exact unless I stack resistors.  Stacking is not an option with these because they are each 1.75 inches long and space is limited.  What I would like to do is use a 200 ohm 25 W, 10 ohm 5 W and 33 ohm 12 W.  The question is, how exact should be the replacements?
Thank you.
Glenn
I'm coming up with a bit less wattage than you. The 200 ohm section actual dissipation is a little more that 1.6w. So a 7.5 or 10w unit would be a good choice. The other 2 are under 1/2 w so 2w would be fine. Figured based on 90ma current flow thru the hv winding. Could be less.
Terry:
I obviously have a lot to learn and appreciate the help.  Your reply makes a huge difference in how I intended to tackle the rebuild.
Thank you for taking the time to respond.  Stay well!
Glenn
Mouser. I like the black (color) wire wound units from Vishay.
Your 200 ohm WW for about $2:
https://www.mouser.com/ProductDetail/Vis...Ap4el4c%3D
Russ
Thanks Russ I will check them out.
Glenn
Glenn
Hello GRG,
I am with Russ those are good resistors and far as the value with in few ohms is not a big deal Because the voltages nowadays are higher and your filter capacitors too .
Sincerely Rich
Thought I'd post a picture of the replacement I made for the 3 section candohm.  Found enough parts in my existing supplies to make it work.  The 5W 20 is two resistors in parallel to get to the 10 ohms needed. The Radio is now working well.
Glenn
Looks great Glenn.
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
Welcome to the Phorum, Phil! Lots of friendly help here to assist you along the way! Take care, - GaryGarySP — 10:55 AM
Hi Pdouglasti, Phirst off, welcome to the Philco Phorum, a Phamily Phriendly place phull of phun pholks and all things ...MrFixr55 — 07:37 AM
There are currently 841 online users. [Complete List]
» 2 Member(s) | 839 Guest(s)
