38-10 Finished
I did not strip and refinished this one. Instead, I repaired two veneer chips on the top, lightly sanded the old lacquer on the photofinish on the front, applied stain to the front, to deal with a scratch and three gouges, used toned lacquers to refresh the finish on the top and sides, then applied clear gloss lacquer.
This radio works very well, pulling in AM stations without any antenna, and shortwave this morining with just an 8' wire.
For safety, I installed a three wire cord (Sundial Wire), and a fuse. This radio performs significantly better with the chassis grounded. I omitted the original capacitors from each side of the power cord to the chassis, as they would put AC on the chassis, and with the three wire cord, be dumping power into the ground, a hazard. I installed an X-safety capacitor across the hot and neutral wires (after the switch).
I carefully cleaned a few rust spots with Naval Jelly, then carefully polished the chassis with Simichrome.
The $39.95 original price is $600 in today's money, so it was a significant purchase for the original buyer.
I have about $115 in it:
$25 purchase price
$25 miscellaneous (capacitors, cord, plug, terminal strips, de-soldering wick, chemicals, lacquer, sandpaper, etc.)
$23.00 new dial from Radio Daze
$7.27 6Q7G
$2 6K7G had in stock
$2 6F6 had in stock
$2 6A8G had in stock
$4.50 chassis screw sleeves
$24 reproduction tuner supports (3), dial bumpers(2), chassis corner mounts(4)
The first two photos show the effect of lighting, angle, and flash on the apparent color of the finish.
[Image: http://i269.photobucket.com/albums/jj77/...nished.jpg]
New (reproduction) dial and rubber dial bumpers
[Image: http://i269.photobucket.com/albums/jj77/...umpers.jpg]
new rubber chassis mounts
[Image: http://i269.photobucket.com/albums/jj77/...isfeet.jpg]
new rubber tuner mounts
[Image: http://i269.photobucket.com/albums/jj77/...mounts.jpg]
Before (I had the piece for the large chip, so glued it back, and fixed the smaller one with new veneer)
[Image: http://i269.photobucket.com/albums/jj77/...before.jpg]
[Image: http://i269.photobucket.com/albums/jj77/...ek/003.jpg]
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
Wow! Beautiful! Very well done! Icon_smile Icon_thumbup
Mike
Very Nice!!!!
Thanks! It looks nice in our radio room.
You did a great job, Stephen. Icon_thumbup Icon_clap
Nice Job on a sweet looking radio !
Thanks, Ron - it is good to read that from someone who is a "Mr. Philco."
Outstanding restoration.
Thanks for preserving another piece of our radio heritage - especially a Philco.
Chuck
Wow, now two "Mr. Philcos." Thanks!
Since I have a 38-7 which I like better, I sold it at the Antique Phonograph Society event last year. Nobody offered more than $115, so that was my selling price. With zero for my efforts, that is what I had in it, so break even it was. With economic recovery far off, and even more so in California, I've cut way, way back on radio buying.
That is a beautiful radio!
Wonderful job.
Excellent job on the chassis! I am currently doing a resto on a model 15X chassis and am also going for the natural metal finish look. It's a lot of work!!!!!
Very impressive
Thank you for helping me with my 38-10F project. It is now in fine working order.
In some cases the old paper caps can be replaced with ceramic caps, with values such as .001 uf, .005 uf, .01 uf, and ma...Arran — 06:50 PM
Vlad; I would tend to agree, I only suggested the loop antenna connections since he was already looking at the end of...Arran — 06:18 PM
Rod thank you for helping to understand the paper caps and offering the bumblebee caps. I have already ordered film caps...osanders0311 — 03:55 PM
Bob, this is the wrong sequence to look for problems and setup circuits. Always start checking the signal path from the...Vlad95 — 12:19 PM
Philco J1720 stereo and record player with reverb
The above link takes you to the Delaware Valley Historic Radio club. They are not too far from you and may have sugg...klondike98 — 11:49 AM
Tucker Movie Prop car
Richard: Did you ever check with your friend? About once a year I try to verify if Mr Rhoades really worked on the r...WrenchMonkey — 09:22 AM
>>when turning the knobs This is very broad. There are knobs for tuning and knobs for volume, and possibly f...morzh — 07:36 AM
Thx Arran, I will check the antenna connections. Right now the loop is alligator clip connected to the chassis since you...klondike98 — 03:58 AM
Bob; I was just thinking that maybe the 1R5 tube doesn't like being operated at 1.2 volts on the filament, though you...Arran — 12:56 AM
So I just purchased a Philco J1720 stereo and record player. That has some static when turning the knobs. Wanted to see ...PhilcoJ1720 — 12:26 AM
There are currently 1006 online users. [Complete List]
» 1 Member(s) | 1005 Guest(s)
