Philco 42-350 Pushbuttons
How and where does one get reproduction labels for the stations buttons on a Philco radio. Any tricks in the how to of replacing them?
Ray
You'll probably have to make your own on your computer.
You can find some tips on how to do this here:
http://www.philcoradio.com/phorum/showth...p?tid=2538
I found this on the internet.
http://tubesandmore.com/
then type "radio station" in the search box.
Danny
I have a 1:1 color scan of the call tab sheets for 1941 Philcos on my website:
http://www.philcorepairbench.com/pdf/194...llTabs.pdf
Print out full size and just cut out.
Chuck
With thanks to Chuck Schwark for furnishing the PDFs, you may now download 1941 and 1942 call letter tabs here:
http://www.philcoradio.com/tech/calltabs.htm
http://philcoradio.com/phorum/showthread.php?tid=4355
[split] New member...
You may have to start further back with your signal injection at the IF signal grid, then tune the second IF transformer...RodB — 10:28 AM
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
There are currently 985 online users. [Complete List]
» 1 Member(s) | 984 Guest(s)
