Bakelite Block 3903N
I am working on a Philco 52b and it uses Bakelite block 3903 N.  I have looked at the reference page on the Wayback machine and it shows its as having lugs 3,5, and 8.  So far so good mine does too.  Then is shows the .01 ufd condenser is connected to lugs 5 & 8.  Close examination of mine before unstuffing reveals wires coming out of the inside and attaching to all 3 lugs.
   Does anybody have a copy of Ray Bintliff's book to help identify what is the correct configeration?
PS. I am definitely going to buy a copy of his book if I can find one.
It is a mistake to think you can solve any major problems just with potatoes.
https://philcoradio.com/library/index.ph...ondensers/
Thank you Terry but that doesn't add any additional information.  I am hoping to find a diagram that will clear up the connection mystery.
There's also clues if you look at under the chassis layout vs the schematic.
You're right. It looks like lug 3 should just be a support but the work by a previous technician has made a mess of this area. I think I remove the insides more carefully than usual in hope of being able figure it out.
Here it is from Ray's book. Sorry about the size.
Henry
Much appreciated, radiohenry. This gives me a much greater confidence in the correct confiuration. I have ordered my copy of this valuable reference. I don't know what has taken me so long.
Thanks again,
Dwayne
Mike, This is just a thought, the are on the coil where the verdigris (green oxidation is) I wonder if that is where ...Arran — 06:32 PM
Mike; I've made a one or two spiders by using some card stock, and a razor blade, it took more then one try but they ...Arran — 05:48 PM
Philco 91 Restore Code ??
I wondered about that. Wish there was some place local to get this stuff.dconant — 04:20 PM
Philco 89 indicator light.
Bending the lamp bracket (moving the lamp, that is) can possibly change the shape of the pointer a bit, but not its loca...morzh — 04:01 PM
Because the usable power rating of it hen is (3,200/20,000)*25W= 4W. Maybe a tad more due to the mass, but not much. Yo...morzh — 03:59 PM
Thank you Dan, that was the trick. I kept trying to rebend the lamp bracket but that wasn't doing anything to help.Jim Dutridge — 02:18 PM
20K 25 watt. I thought it was a 20 watt at first.dconant — 01:37 PM
My Philco 37-116 Restore
Nah, too much and not that important.morzh — 01:33 PM
What's the full value of that resistor?morzh — 01:31 PM
Been running the radio for three hours now. The power transformer has settled out at 140 degrees. The filter choke is ab...dconant — 12:38 PM
