Need a little help....
How do I post pictures from my computer? I have some interesting things I'd like to get some comments on.
There is an instruction somewhere here, but you should edit in full mode or press "New reply". Them you will have the buttons "New Attachemnt" "Browse". When browse, you will browse to the picture, then when you pick it pres "Add Attachement".
Then your file will appear below, and you press "Insert into post ".
They will appear in the order you put them. If not they will appear on some order anyway.
Go to the Phorum home page.
Scroll down - yes, keep scrolling - wow, there's lots more here than I thought! - keep scrolling until you get to the section Rules, How-To, Donations.
Click on the link How to Do Things in the Phorum.
Now look for these links:
Overview: How to Add Images to Your Posts
Phorum How-To #14: Attaching Files to Your Posts
I picked up a Philco 41-315 console this morning at a garage sale. It's missing some tubes, needs a ton of cabinet work, and is basically a dirty mess, but what the heck, I need the experience and it cost me all of 20 bucks. After the lady helped me load it into my car she handed me a bunch of old papers she said came with the radio.
She wasn't kidding! The old papers contained a basically complete Philco Station Tab Call Letter Kit, a Philco radio Log, the loop antenna placard, installation instructions, and even the cardboard chassis inserts the installation instructions tell you to remove when you receive the radio.
I don't know how often you guys get stuff like this when you find a radio, but I was really surprised at the completeness of her "papers." What's this stuff worth?  Here's some pics of it:
Thanks, morzh. I'll get the hang of this site eventually.
Mike; I've only run into a speaker with an open filed coil twice, and they were on newer speakers from the 1940s. One ...Arran — 12:48 AM
Arran Yes, this is my plan for now and what do I got to lose, this is not even the speaker from this radio, but one o...morzh — 10:44 PM
Mike;  I would unwrap the field coil, and see if maybe there a break near one of the ends, like where the coil wire att...Arran — 10:23 PM
...and this is what I did. I fed a little LT into the screwholes with a small brush, and a little on the rim next to the...morzh — 09:52 PM
Philco 40-120C Restoration
I combined the two 40-120C threads together as we like to keep the discussion of the same radio together. It helps with...klondike98 — 09:36 PM
Philco 40-120C Weak, Distorted Ouput
Just checked were I buy tubes price is four dollars. So living in Florid we have a local source for tubes. David    David — 09:14 PM
The higher voltage may be due to higher mains voltage. My mains run 120-125AC when the set was new mains would be 110-11...David — 09:09 PM
Thank you for your reply. I pulled a speaker from a Philco 41-221 and received the same result. I used a signal tracer t...bluecap — 08:45 PM
Have you tried a different speaker? How did you trace the distortion? How do you know it is weak? What is the reference?...morzh — 08:33 PM
Amen to that! Every time I think I’ve captured them all, I realize that there’s another error. My goal is to finish with...jrblasde — 07:00 PM
