Model 70 1st det. coil
Hi All,
I'm working on a model 70 and I have an open primary winding on the 1st detector transformer- Philco part no. 03083 item number 6 on the schematic. Does anyone have the info on how many turns, which direction and gauge of wire? Any info would greatly appreciated! Thanks!
Took a quick look at the diagram and the winding you are looking to rewind is a non frequency determining (untuned) The number of turns is not real critical. What I would do is use some #36-38G wire. Rewind to fill the same space of the original. I would suspect it's about 55 turns. You can determine the direction when you remove the old one.
Thanks for the info Terry! I pulled the coil out and found out the direction (should have thought of that earlier!). I've measured the width of the winding and will try to count the turns.
Kevin
I was a field engineer for a biomedical company for many years. Many was the time that I was driving home from NYC in t...MrFixr55 — 06:40 AM
Don't laugh folks, I have not been above taking a chassis into the bathtub (when Ms. Fixr was out of the house), taping ...MrFixr55 — 06:02 AM
Philco model 40-100
Marion; By "newer style" carbon resistors do you mean the molded type with coloured bands rather then the BE...Arran — 01:00 AM
hello jrblasde , your radio sounds great well done !! I bought like 20 years ago a Philco 610b that someone had painte...radiorich — 11:50 PM
Philco model 40-100
Arran, I just can't tell if the volume control has been replaced. The control has a brass shaft with one half flat for ...mhamby — 11:08 PM
Philco model 40-100
You may be able to make the part out of wood. The particular vendor has a habit of disassembling radios and selling the...MrFixr55 — 10:09 PM
Used to get to Bentonville when I worked for a Walmart vendor....nice and sleepy back then. PaulPaul Philco322 — 09:49 PM
Philco Model 249 made in England
Did Garrard produce stand-alone turntables? The reason I ask is, when I was a kid my grandfather gave me a KLH Model 20 ...jrblasde — 09:37 PM
Neat looking set, definitely Euro- style. I am guessing that this is solidstate due to the vent holes (or lack thereof,...MrFixr55 — 09:32 PM
Haha, thank you sir! I’ve been eyeballing a 47-1230 console for sale over north of Bentonville, Arkansas for a while. Pr...jrblasde — 09:18 PM
There are currently 652 online users. [Complete List]
» 2 Member(s) | 650 Guest(s)
