Good way to fix this blemish?
Would like some advice on repairing this small blemish. It is a light gouge but it does not go all the way through the mahogany veneer. What products would work best? Here are pictures:
That's almost a job for "tinted lacquer" sprayed from an airbrush in very thin layers, blending edges by lightly overlapping as you fill to the centre.
If it really is small, try one of the (hot) wax sticks in the appropriate color.
Pictures just loaded - not small. Yes, some toner carefully applied with a brush or blotter. You can make it good enough that other people won't see it - but you know where to look. classic toner, dark walnut. A repair that is too dark will look better than a repair that is too light (to me).
Thanks for advice y’all. Now, It’ll just be a matter of skill ?
It'll be a case of patience, more than skill I think. The important thing to remember is that this finish is NOT a stain IN the wood grain. It is a colored (tinted or toned) surface layer of a hard finish (lacquer) OVER the wood grain.
And yes, I agree that slightly darker will likely work better than a lighter tone.
Philco 37-116 Cabinet Repair
It looks to me like the structure under the veneer may have expanded from humidity cracking the veneer on the surface. W...Arran — 09:42 PM
Help with Supreme 599
Iam only getting 4vac out of the tranny For the 80 filament. The line rheostat Looks fine and the tranny is getting 11...daveone23 — 08:45 PM
Rogers Majestic R-646
Transformers rewind? It's very easy! If you don't have round eyes  8-) Vlad95 — 01:55 PM
I found a broken wire from the end og the 300 ohm line adjust to the transforner but i dont think its needed. The transf...daveone23 — 11:43 AM
Philco 38-10 Tuning Condenser
RodB I have been using pure Vaseline for a long time for thick lubrication of home radio devices. The main reason is t...Vlad95 — 10:58 AM
Vlad, your comment about Vaseline brought a thought. Does anyone know the long term affect on using silicon grease on t...RodB — 10:34 AM
Arran, didn't notice the specifics for the caps. What's the code going to get me? I'm working on restoring a Philco 50-9...RodB — 10:26 AM
I managed to get the gears lined up and the springs back in. Much easier than it thought. Putting a thin wire down insid...dconant — 09:52 AM
Rod, Mrfixr55 and everyone else thank you very much for all your help with this radio thus far. Today will be more testi...osanders0311 — 09:26 AM
Thanks for the reply Vlad95. I can't even see the balls let along try to remove them. The grounding forks are going to p...dconant — 08:03 AM
There are currently 695 online users. [Complete List]
» 1 Member(s) | 694 Guest(s)
