Mechanical OFF/ON indicator
Working on a Canadian model 209 which corresponds to 41-95T, which has a mechanical indicator (red for on) in the middle of the dial itself.  This is driven by a length of dial cord and I think a spring arrangement which is missing from mine.  Anyone have a similar radio?  I have another Philco with this indicator but it is direct driven and very close to the off/on switch and no need for dial cord.
Thanks
I have a similar set; it's a battery chassis.
Does your's work directly from the switch or is there cord/spring arrangement that moves the indicator? I'm missing some parts of it on mine I'm sure.
Found the same radio on youtube, the cord makes a 3-point loop on the metal tab with a spring anchoring the one end of the cord, and the other end goes to the cam on the off/on switch.
Need Help to ID this radio 11 tube Philco
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
1.7-3.9 %, a modified Sine wave inverter is around 25%. Most generators from big box stores run 10% at a 50% load. What ...David — 04:06 PM
I am having a heck of a time doing the alignment on the AM band. I can't seem to dial in the 1500 KC oscillator. I can h...dconant — 03:35 PM
David - I think I understand but what units are you discussing (Low of 1.7, high of 3.9)? Budget constraints for Ham ...EdHolland — 01:43 PM
There are currently 743 online users. [Complete List]
» 2 Member(s) | 741 Guest(s)
