Do you recognize these knobs?
I suspect they go with some other brand/model.
They look very much like knobs from an Arvin 618.
                                      Henry
Hi OSanders. another thing about the loop antenna is that it is directional. Try turning the radio in different direct...MrFixr55 — 09:19 PM
The 630v caps will do just fine. Physical size increases with capacity values and voltage. You don't have to replace 200...RodB — 09:09 PM
Help with Supreme 599
Good catch. The 589 is a better schematic but i dont understand how the voltage goes thru the meter to adj the line volt...daveone23 — 08:17 PM
Arron, Yes, I can see the differences in the interior design, but if you compare the schematics, they look very similar...Vlad95 — 06:57 PM
I am not sure how the loop antenna supposed to work but think I have figured it out. I had one lead on terminal 1 and go...osanders0311 — 06:56 PM
Thx Vlad.klondike98 — 06:54 PM
Rogers Majestic R-646
Hi Arran. I continue to disassemble and I see that the interstage transformer is completely beyond repair. It is placed...Vlad95 — 06:50 PM
Hello Rod " If you're not using the 0.33 mfd 200 volt ones for this project, they are excellent tweeter crossover ...osanders0311 — 06:25 PM
Vlad; My set had the same faults as yours when it was about 30 years younger, so I think that these components are sus...Arran — 05:11 PM
If you're not using the 0.33 mfd 200 volt ones for this project, they are excellent tweeter crossover caps.RodB — 04:56 PM
There are currently 362 online users. [Complete List]
» 2 Member(s) | 360 Guest(s)
