model 20 dog bone resistor values
I want to replace the 5 dogbone resistors. I can not find the equivelent part number/codes for these parts. I would appreciate any help you can give.
Why do you need the part numbers? You can't just go down to the Philco distributor and get these anymore...
Anyway, your wish is my command:
(12) 50,000 ohms, part no. 4237
(15) 250,000 ohms, part no. 3768
(17) 500,000 ohms, part no. 3769
(18 ) 100,000 ohms, part no. 3767
(20) 500,000 ohms, part no. 3769
Here's some additional info where they are listed by wattage.
http://www.philcorepairbench.com/carbonres.htm
And if yours aren't shown in the list click on the comparison pictures link. That is handy for all old dogbones, not just Philco.
You will probably have to resort to modern values like 470k instead of 500k, etc.
GL,
Bill
thanks for your help. Ron, which site has these part numbers? I understand you don't sell them.
You aren't going to be able to find those parts any longer more than likely. I'd recommend you get modern equivilents...
Try http://www.justradios.com : http://www.justradios.com/rescart.html
Look for ones that are as close as possible in the 1W Flame Proof column. They come in packs of 5.
50k ohm would = 47k ohm
250k = 250k
500k = 500k
100k = 100k
Brian Mattson
Coon Rapids, MN
Philco model 40-100
Arran, I restored 2 Canadian battery-crank telephones for a friend a while ago, a Northern Electric (Canadian version of...MrFixr55 — 08:04 AM
Road Trip for a Philco 46-480
Beautiful work, a 79 year old radio brought back to life. The first FM radios for me, a little iffy, had some I just cou...Jimradio — 08:01 AM
I was a field engineer for a biomedical company for many years. Many was the time that I was driving home from NYC in t...MrFixr55 — 06:40 AM
Don't laugh folks, I have not been above taking a chassis into the bathtub (when Ms. Fixr was out of the house), taping ...MrFixr55 — 06:02 AM
Philco model 40-100
Marion; By "newer style" carbon resistors do you mean the molded type with coloured bands rather then the BE...Arran — 01:00 AM
hello jrblasde , your radio sounds great well done !! I bought like 20 years ago a Philco 610b that someone had painte...radiorich — 11:50 PM
Philco model 40-100
Arran, I just can't tell if the volume control has been replaced. The control has a brass shaft with one half flat for ...mhamby — 11:08 PM
Philco model 40-100
You may be able to make the part out of wood. The particular vendor has a habit of disassembling radios and selling the...MrFixr55 — 10:09 PM
Used to get to Bentonville when I worked for a Walmart vendor....nice and sleepy back then. PaulPaul Philco322 — 09:49 PM
Philco Model 249 made in England
Did Garrard produce stand-alone turntables? The reason I ask is, when I was a kid my grandfather gave me a KLH Model 20 ...jrblasde — 09:37 PM
There are currently 578 online users. [Complete List]
» 3 Member(s) | 575 Guest(s)
