Philco 38-14 dial cover removal
How are the steel clips that hold the speaker grille and plastic dial cover removed in a Philco 38-14 cabinet without breaking the bakelite studs?
Thanks!
Chuck Owens
Use a dinky flat blade screwdriver to pry (bend) gently the tab of the metal clip that is contacting the bakelite post. Do both tabs till they release then remove the clip. Flatten clip out to reuse. If you are not gentle you'll snap the bakelite post off and say bad words...
Now I think I've got it!
