46-1201 bing crosby dial cord
Hello.  I am working on a bing crosby and am having trouble with the dial cord.  The existing cord is with the radio, but the dial pointer cord had come off the wheels.  I found a diagram and reinstalled the cord per the diagram, but the pointer is moving in the opposite direction from the tubing gang.  For the life of me I don’t see how it is possible for this setup to work.  The low end on the dial is on the least when looking at the radio.  The variable capacitor tuner becomes fully closed by turning it counter clockwise. The pointer dial cord comes off the top of the tuning gang which moves the pointer/cord towards the upper end of the dial when the condenser is moving towards the closed position. What am I missing?
Pay attention to how the cord wraps around the tuning shaft; clockwise or counterclockwise.
I’m sure I have the cord installed the same as the diagram. The pointer rides on the bottom of the scale witch is the only way it will fit. The cord for the pointer comes off the top of the top of the drive wheel and goes to the left along the top to the first pulley.
With this setup a counter clockwise turn of the tuning knob moves the pointer to the right towards the top of the AM band. The large drive wheel is attached directly to the tuning condenser. The tuning condenser is tuning stations (455 fully closed, counter clockwise, and 1600 fully open clockwise), but for this setup to move the pointer to work it would have to be opposite. Is it possible the tuning condenser is backwards in its operation?
Sorry for the stupid post? I have the chassis on the bench and not in the cabinet. I just realized the chassis is mounted upside down in the cabinet. Duh.
Bet you're not the first! Those development engineers' ghosts are getting another big laugh.
We've all done something like that at one point or another!
Need Help to ID this radio 11 tube Philco
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
1.7-3.9 %, a modified Sine wave inverter is around 25%. Most generators from big box stores run 10% at a 50% load. What ...David — 04:06 PM
I am having a heck of a time doing the alignment on the AM band. I can't seem to dial in the 1500 KC oscillator. I can h...dconant — 03:35 PM
David - I think I understand but what units are you discussing (Low of 1.7, high of 3.9)? Budget constraints for Ham ...EdHolland — 01:43 PM
There are currently 733 online users. [Complete List]
» 3 Member(s) | 730 Guest(s)
