Philco F-1740 Car Radio
I have a 1940 ford car radio I'm trying to repair I am a stand still.
Vibrator works tubes light up have voltages to tubes still nothing.
Help
Check that speaker is working, output transformer is good. Did you replace all the paper caps and out of spec resistors?
here's a schematic for the L-1760. http://www.nostalgiaair.org/PagesByModel...014047.pdf
i have a schematic for the F-1740. they are similar but with different part numbers. and the L-1760 has two 7C5 audio amp tubes.
https://www.radiomuseum.org/r/philco_f1740.html#top isn't much help.
the outer winding on the lone oscillator transformer of older transitones frequently corrodes and is open. you might check the main osc coil [part no. 59 on the L-1760 schematic] for continuity. the antenna and RF transformers, too. and, i suppose all the other osc coils.
touch the tip of a soldering iron to the grid of the 7C5 audio tube. plug the iron in but leave it off. you should hear a hum if the audio stage is good.
you need to see the word "dial" in the left window to use the tuner.
There are currently 2181 online users. [Complete List]
» 1 Member(s) | 2180 Guest(s)
