11-17-2021, 04:32 PM
I am working on an earlier model 60 (pre wave trap). I have replaced all the caps and a few our of spec resistors. All the tubes test good (and I have also swapped tubes from a working 60). The speaker, output transformer, and assoicated wiring is good (I also swapped a working speaker and related parts from a working 60.) The set powers up, and with an antenna attached will receive stations along the entire dial, but the volume is a whisper. The volume control works and will take the volume from 0 to a whisper. The volume pot is good and I also swapped a working pot from another radio with the same results. Touching the volume pot connections does not produce a buzz or hum. I am at a loss. I compared voltages to the working 60 and nothing iappears to be alamingly different. Since it receivce stations does that mean the various transformer coils are ok?
Ideas?
Ideas?
