Philco Tropic 3212-121
Hello All,
I'm having zero luck finding any information for this radio, other than it was manufactured in 1950. It has 4 shortwave bands and AM. Tube lineup is 7S7, 7B7, 7C6 and 6AK6. Can anyone point me to a resource for schematics and service information?
Thank you.
Cheers,
Scott
Took a quick look and found this: https://philcoradio.com/library/download...-final.pdf Interesting a 6v farm set.
I don't think we have a photo of that in our library or gallery. If you are willing, would you post a nice photo of it so we can add it to the files. We'll credit you with the photo contribution.
Thank you for this information. The search option on this site didn't find any results; I see that I should have searched the archives manually.
I will post some photos once I clean this set up and determine the way ahead. The tuner is frozen and, unfortunately, someone in the past removed the 6V power supply and substituted a multi-tap power transformer and selenium rectifier. I've some work ahead of me.
Cheers,
Scott
Thanks Scott!
Here are two photos of the 3212 case. This one is going on the back burner for a while. I'll circle back with better pictures once I've restored it.
Thanks very much!!
Rogers Majestic R-646
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
There are currently 1011 online users. [Complete List]
» 3 Member(s) | 1008 Guest(s)
