  • 1 Vote(s) - 5 Average
Philco 90 restoration
#91
There's nothing as satisfactory as a good whacking that yields some results. Doesn't even matter what or whom you are whacking. As long as it works.
#92
If the hammer had not worked I was going to suggest using a hydraulic jack under something solid to press it out, such as the main beam of the house, or a truck frame. The prior option would have involved using a wooden post on top, with a jack under it, a socket or stub of pipe under the jack, the speaker rear bracket, and a pair of blocks at the bottom, or one block with a hole drilled in the center.
Thank you for all the creative solutions. A press seems like a handy thing to have and I'll keep my eye out for one.
I've been unwinding the field coil and found a couple breaks so far including this one in the center of the photo. It looks a little bit melted which makes me think it was overloaded or arced.
Still no continuity...
[Image: https://live.staticflickr.com/65535/5171...2c31_c.jpg]
#94
I found the break with about 2.7K resistance left. I think that's about 80% or so. I plan to splice and wind some wire back on rather than take it all off and rewind from scratch.
Heck, I could probably leave it at is and add a resistor to make up the difference.
As for the chassis, I replaced some crumbling wiring, installed a new line cord and added a fuse hidden inside some red heat shrink tubing.
I just installed the two small filter caps under the chassis rather than restuff. I'll put the old caps back in but leave them disconnected.
[Image: https://live.staticflickr.com/65535/5171...0f6b_c.jpg]
I told myself I wasn't going to detail the chassis, but I just couldn't help myself. Here's one corner after some rust remover and Boeshield T-9 rust inhibitor.
If I had to do it over again, I would have broken down the chassis, cleaned up all the parts and reassembled.
[Image: https://live.staticflickr.com/65535/5171...eed9_c.jpg]
#95
Beautiful! So you put in new mica caps for 14 and 19?
#96
Hello Bob,
I can see you have been really busy
the radio looks great so far !!
P.S. my next Philco is my 38-10t
or I may fix my little Philco tiny oscilloscope.
#97
Mica cap #14 is listed in the parts list as "110 mmf". What does that mean? #19 is listed as a more reasonable 0.00025 mfd.
#98
Hi Chris - Here's the scoop on capacitor values; mmf is the "old" designation of micro-micro farads. We used to call them micky-mikes. Today they are pico farads. So your mica cap is 110 pico farads (pf). Also known as .000110 mfd. BTW I've seen pf used in mid 50s German schematics, so pico is fairly old too.
#99
The "Farad" is the basic unit used to refer to the quantity of charge a condenser, (modern term is "capacitor") is able to store. a MICRO farad is 1 / 1,000,000 of a farad. a MICRO MICRO farad (now commonly called a pico farad) is 1 / 1,000,000 of a micro farad. So, 110 mmf = 0.000110 mfd. You will find some of us old timers still call a condenser a condenser, and a micro micro farad a micro micro farad, and not the new fangled name. Worse yet, and to ADD to the confusion is the new addition by some fools of the term NANO farad which seems to mean 1 / 1000 of a micro farad, FORSOOTH ! In the saner documentation of the earlier period, however, you will only have to deal with mfd and mmf.
Well said, Mike. I never understood why we didn't use milli-farads.
I replaced those mica caps while troubleshooting a problem that turned out to be an open coil. The originals mica caps were fine I just didn't bother putting them back in.
I've seen several restoration videos on old radios, maybe you made this comment as well (I can't remember) that these mica caps in vintage radios were installed as custom, "fine tuning" capacitors and probably should not be messed with although I don't see how that could be the case for a component in the general parts list with a specific value indicated.
Although the theoretical value might be 110pf the actual value of any one mica would vary because manufacturing techniques weren't as precise as the theory. The same with other components such as resistors and coils. So maybe the specific circuit of a specific radio ended up requiring 114pf. The assembler would find one that worked the best. Maybe the next radio would need a 108pf. They were customized for the radio.
Mike, would you like to re-phrase this?
I don't think values were selected as the radios were assembled instead, trimmers were used to compensate for the variation of component values.
M R Radios   C M Tubes
Need Help to ID this radio 11 tube Philco
RCAs ain't no cake either.morzh — 10:32 PM
After a couple of days worth of troubleshooting my signal generator, I gave up. The oscilloscope still worked fine, so I...jrblasde — 09:51 PM
48-482 rear panel help
Yes, I can confirm. I bought one (haven’t restored it yet) which didn’t have a back panel.jrblasde — 09:37 PM
Try a 39-116.Radioroslyn — 09:24 PM
I remember Philco 45 being awkward. If I am not mistaking it for some other set. I think there is a phenolic board, or e...morzh — 08:49 PM
If you want a radio that's difficult to work on, get a 37-620. The one side of the chassis is packed pretty tightly and ...Greg — 07:29 PM
Philco 16 is not intimidating at all. Despite being an 11-tuber. 37-116 is indeed intimidating. 16 has good space unde...morzh — 04:11 PM
Thanks for the responses Gary and Bob. I'm a little surprised that there's no back panel - although I know older Philco'...keithchip — 04:09 PM
Gary is correct, there was not a rear panel on the 48-482. I restored one of those and its a great sounding radio that ...klondike98 — 03:24 PM
A little light positivity in our feed... To nostalgic retro music... With English subtitles My new video on the contin...RadioSvit — 02:14 PM
