  • 1 Vote(s) - 5 Average
Philco 90 restoration
Absolutely. If the value was critical, they put a variable cap in parallel with the fixed cap.
Yup, as Steve and Bob said. After all, these were consumer products, not scientific instruments. Usually "good enough" was...good enough. Icon_smile
I watched a YT video from Mr Carlson last night on restoring an FADA radio. That's where I heard the comment. Doesn't mean he's right though! Maybe it was something unique to that manufacturer.
Could the components even be selected before the radios have been completed and powered up? Anyway, just think about the bottleneck this would create on an assembly line.
M R Radios   C M Tubes
The design engineers selected the components when they designed the circuits, prior to the beginning of production. Changes were (often) made during production, and these changes were then incorporated into production and usually (but not always, as we know) documented.
It just wouldn't be economically feasible to select components on the fly.
Makes sense guys. Wow...these pictures on the Philco radio website are haunting. I live right outside of Philadelphia and know exactly where this area is.
https://philcoradio.com/library/index.ph...9-the-end/
I believe that the old style molded mica caps had a tolerance of + or - 5%, and since the values were usually posted right in the service data, either on the schematic or on an included parts list. Of course they also included trimmers, and padder condensers in series with, or in parallel with a coil to compensate for the variations in manufacturing tolerance between one coil and another, some would take shortcuts though and use fixed micas rather then trimmers. I've never worked on a Philco superhet of this era, but I have worked on RCA/G.E/Westinghouse sets, and it is possible to get the alignments on those almost bang on in terms of dial tracking.
Bob, PM'd you regarding your "parts chassis"
Simon
I'm calling the chassis done. It would be nice to have a matching pair of tube shields but I'm not going to lose any sleep over it.
Next, I'll give the speaker my full attention.
[Image: https://live.staticflickr.com/65535/5173...1586_c.jpg]
Hello Bob,
beautiful job!!
OOPS!! if there is a "flag" running up the side of the tube that touches the shield, then yes, a shield belon...MrFixr55 — 10:03 AM
Thanks for pointing out that shield! I will try to find out where else it may belong. I simply installed it back where i...jrblasde — 10:02 AM
Very nice job. A real contrast between how easy the main chassis is to work on, vs how tightly the RF chassis is packed...MrFixr55 — 09:31 AM
After sleeping on it, I believe the issue is that I may have forgotten to install a ground connection between the RF cha...jrblasde — 09:21 AM
Refinishing Ideas
Hi Poulsbobl, I think that you could get away with it.  In the Philco Library, there is a parts listand specs for sp...MrFixr55 — 11:54 PM
The sleeving for the transformer arrived early, so I went ahead and finished reassembling. The chassis looks far better ...jrblasde — 10:15 PM
I don't know what you are referring to when you say "tube cathode ground". Ground is a connection to the chass...RodB — 05:56 PM
Good points, Arran. I haven't encountered this problem with any other radio (all earlier vintages), so am learning here....EdHolland — 05:32 PM
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
There are currently 770 online users. [Complete List]
» 4 Member(s) | 766 Guest(s)
AvatarAvatarAvatarAvatar
