New Guy With a 42-345
Hello All!
My wife's father bought this radio when he was in the war. Her sisters want me to restore it. Needless to say, it has sat in a basement for many decades. I'm up for the challenge though. Question: Where can I get the selected band graphic shown in red on the right? Radio Daze doesn't have it. I also need new pushbutton decals. Any suggestions?
Hi,
You can make your own pushbutton tabs - details here:
https://www.philcoradio.com/phorum/showt...p?tid=5148
As far as the band indicator is concerned, that has never been reproduced by anyone. If yours is missing or otherwise unusable, your only alternative is to find a parts set of the same model number which has that celluloid indicator still intact.
Cool. Thanks.
I might try to do something with clear decals for the band indicator.
Rogers Majestic R-646
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
Philco 89 Code 123 Osc Coil
There are currently 1012 online users. [Complete List]
» 3 Member(s) | 1009 Guest(s)
