46-480 Rear Cabinet Cover
Hello everyone.  I've recently acquired a Phlico 46-480 and am in the process of restoring both the electronics and the cabinet.  The cabinet is in pretty good shape but when I got the set it was missing any type of rear cover.  I've looked pretty closely at the cabinet's rear and haven't seen any screw holes or other mounting hardware which would secure a back cover.  This begs the question:  Did this radio originally come with any kind of a back cover?  If not I'm OK with leaving it open but if it did have a cover I'd like to fabricate a new one.  Any pics or information on this would be greatly appreciated.
       Pete
I have seen some 1946/47 Philco consoles with a cardboard cover over the speaker compartment only. But the radio portion had no back.
Keep in mind most prewar radios, and some postwar models as well, never had backs. It was understood that parents would teach Junior and Sally to stay the heck away from the back of the radio. Common sense, you know. That thing that has all but disappeared today. Icon_rolleyes
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
There are currently 1135 online users. [Complete List]
» 1 Member(s) | 1134 Guest(s)
