Philco 84 field coil wire size
Hello,
I have a bad field coil on my Philco 84 and will try rewinding it. I was able to get the field coil assembly apart and access the coil itself but am not sure of the wire gauge size. I think it might be 35 gauge but would like to know if anyone knows for sure?
Regards,
Ctkid
From what I can tell the coil is rated for 40ma. 35G is good for 42ma as per The Radio Amateur's Handbook 1956 edition
The wire size can be measured with a mechanical micrometer or caliper. Allow a couple of thousands for the film insulation.
Pliny the younger
Thanks for your responses!
I don't know, 40 ma seems kind of low for a set with a #42 output tube, the #80 rectifier tube is rated for 125 ma I think. I would try measuring the actual wire used in the field coil. Of course I am assuming the the field coil in the model 84 is used as a filter choke in the positive side of the B+ circuit, and not in the negative side on the bias supply, which would require a lower current rating.
Philco spec the coil at 40ma for that K speaker.
The speaker used in Model 84 is type SB (not a K) and it has an 1140 ohm field coil rated at 50 mA.
(source: the Philco Speakers spreadsheet, downloadable at this link on this site.)
Need Help to ID this radio 11 tube Philco
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
1.7-3.9 %, a modified Sine wave inverter is around 25%. Most generators from big box stores run 10% at a 50% load. What ...David — 04:06 PM
I am having a heck of a time doing the alignment on the AM band. I can't seem to dial in the 1500 KC oscillator. I can h...dconant — 03:35 PM
David - I think I understand but what units are you discussing (Low of 1.7, high of 3.9)? Budget constraints for Ham ...EdHolland — 01:43 PM
You're doing great. I wish I could be more involved, but my mind is right now preoccupied with the reason I am here in ...morzh — 12:21 PM
Hope you guys are still with me. I have moved on to the alignment. I completed the IF alignment which was pretty muc...dconant — 10:47 AM
There are currently 702 online users. [Complete List]
» 1 Member(s) | 701 Guest(s)
