4 7/8 inch round Philco bezel: Need Model no.?
I have the 4 7/8 inch dial bezel, glass lens and mounting plate. What model is this one for?
Deleted - misinformation on my part - please see below.
Please disregard previous post.
It's been a long time since I owned any of these Philcos, and I did not keep any notes on what escutcheon sizes fit which cabinets. Based on some others I have seen online recently, I must now say that what you have is likely from, and will probably fit, one of the following:
37-630T, 37-640B, 37-641B, 37-650B.
It may fit a 38-5B but is not really correct for 1938 models. (The color scheme on 1938 escutcheons is reversed compared to 1937 escutcheons.)
I have been reminded that most 1937-38 Philco round escutcheons for console models are a bit over 5 inches wide.
I saw your ad so I then knew which models it likely will fit.
Sorry for the prior mixup.
Shadow Meter Bulb
Philco 41-608 changer coupler
12' Philco
12' Philco
Hickok AC51 tube tester
Arran If the wire inside cans is the gauges you mentioned, the sole reason for that would be mechanical, to stiffen t...morzh — 12:56 PM
12' Philco
Rod, Yes, I know, but the Giant Philco is not around anymore either, so I go by whoever was alive fairly recently. H...morzh — 12:54 PM
There are currently 5497 online users. [Complete List]
» 4 Member(s) | 5493 Guest(s)
AvatarAvatarAvatarAvatar
