Restoring Philco model 87
Thanks for the info on the tube..I am going to be careful with anything I do with this radio to make sure that anything I do is reversable. I am patient, I don't mind scouting around looking for original parts, but I do want to hear it play.
Wendell
Ron, or anyone that has a minute Icon_angel
On the schematic that you linked, the filter block diagram was a big help. The block layout corresponds to the bottom of the filter block exactly. This makes a big enough difference that even I understand it. I have one question for you. If you have time to look at the schematic, there are (2) .015mf caps, but they don't indicate polarity. Are those not electrolytic caps?
No, the .015 caps were originally paper as were all of the caps in that can. You can use .015 uF yellow metalized film caps to replace them, and they do not have any polarity. Icon_smile
Thanks again for the help. Hopefully that's the last question. I'm optimistic that this thing's gonna play soon.
Wendell
Wendell,
As I mentioned in my pm I just p/u a model 87.
Being the daredevil that I am I plugged her in
and gave her juice. Everything seems OK but
voltage are way down so it going to get the
filter bank rebuilt. Started in on that but noticed
it takes a lot of heat to get the solder joints
apart. If you cut the wires they'll be too short
to resolder. Just thought I'd mention it to you,
I'll need a least a 60W iron. That will just about
do the job with saying too much bad words.
100W job would be even better. Forget a little
30W shady o rack.
I make sure my iron is well tinned, and I cheat a little by melting a tiny amount of fresh rosin core solder on the tip just before touching whatever I want to create a joint. Of course you should ideally first create a clean and patent mechanical joint which would withstand not being soldered. I like a 40 watt pencil dimmered down a bit, but use the Weller Gun when I'm in a rush, or there is a whole lot of stuff to join. Got a Weller big boy somewhere, and that is just short of a propane torch once you get the tip tightened.
Nobody knows if the original production line people were paid, sometimes it seems like by the pound for solder. It's actually difficult to re-create those blobs with anything available today. higher temperature, different eutectic, anyone?
Speaking of which, please dispose of the waste you dig out of terminals, etc... responsibly especially if it's more than just a little. It's OK to keep it in a jar and turn it in as lead/tin whenever this is done where you live.
Philco 60 Squealing
I just peaked it for the best signal at 600. NULL it for IF frequency, originally it would have been null for 500kh...Chas — 08:05 PM
Philco 60 Squealing
Wavetrap no longer matters.morzh — 05:19 PM
Philco 60 Squealing
Rod, I had checked out your suggestions but did not help. I did solder the ground rivets to the chassis as Chas suggeste...dconant — 04:52 PM
37-690 Bass Choke Replacement
Yeah, I know, Mouser and Digikey don't have "big iron" components. For some reason Philco was messing with the...Radiodial — 04:25 PM
Yes, I just had to deal with that while repairing the 37-604 Philco. Exactly that value choke was gone. And the current ...morzh — 03:52 PM
Ah, now where to find one. I've into this before on smaller sets, I now recall. Hammond makes one that is only rated...Radiodial — 03:27 PM
Philco 38-7 Speaker
Ask the admins to put them together. As for the renaming, while inside the thread, you simply press "New reply&quo...morzh — 02:23 PM
This is the parts catalog. 32-7528 choke is 65H, 10mA, 2,250 Ohm inductance. Find a suitable one.morzh — 02:18 PM
While troubleshooting the no bass amplification issue, I think I found the culprit. The choke #104 is reading 164K ohms....Radiodial — 01:42 PM
Philco 60 Squealing
Your IF transformers are tuned to the resonant frequency they were designed for. When you observe the bell curve they di...RodB — 01:35 PM
