37-610 Half gear in front of variable capacitor slipped??
I'm working on a 37-610 in a Tombstone style cabinet.   I finished all but two capacitors, I have to order more.
I started looking over tuning and it stopped about half-way.  I look in the back and the  variable capacitor is in the right place but then I noticed this little half-gear has reached its end stop.   It shouldn't be stopping right there.   The shaft has serrations that hold this gear in place.   It's a double gear made from two then pieces of metal and there's some springs that hold them together.
So what goes here?   It must have been this way for sometime.   Considering the shaft condition it looks like should have never happened.  It was stiff, maybe someone tried to force it at one point and it skipped.
How do you properly realign this gear?
The two gears w/a spring in between is called an anti backlash gear. It's designed to take up any slack between it and the gear that is driving it. In other words there is no free play.
I'm familiar with the concept, I couldn't remember the term.
Any ideas on how to reset it's position?
It doesn't look like there is any way to change the relationship between the split gear and the tuning capacitor's shaft. It's pressed on. As long as it hasn't broken away or the teeth are stripped off your ok. The planetary drive can be replaced separately and probably isn't a bad idea to disassemble and clean it . They get gummed up stiff.
Here's a couple of pic of the relationship of the split gear vs tc plates from a 37-620.
A funny thing. I finished replacing caps, put a new 3-prong cord on it, oiled the tuning and put it all back together and the problem went away. It apparently didn't like laying on its side on the workbench - now in the upright with all the screws back in it's working great, all three bands, comes in like gangbusters -- best patient I even had.
I'm going to fix the pencil hole in the speaker, put it back in cabinet and send it on its way.
Radioroslyn, thank you for the photos.
Hello Daniel Bingamon ,
wow that is one for the books as they used to say that is a first for me !
Glad you got it working .
Need Help to ID this radio 11 tube Philco
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
1.7-3.9 %, a modified Sine wave inverter is around 25%. Most generators from big box stores run 10% at a 50% load. What ...David — 04:06 PM
I am having a heck of a time doing the alignment on the AM band. I can't seem to dial in the 1500 KC oscillator. I can h...dconant — 03:35 PM
David - I think I understand but what units are you discussing (Low of 1.7, high of 3.9)? Budget constraints for Ham ...EdHolland — 01:43 PM
You're doing great. I wish I could be more involved, but my mind is right now preoccupied with the reason I am here in ...morzh — 12:21 PM
Hope you guys are still with me. I have moved on to the alignment. I completed the IF alignment which was pretty muc...dconant — 10:47 AM
There are currently 720 online users. [Complete List]
» 1 Member(s) | 719 Guest(s)
