substitute tub 7A4 vs XXL
My 42-380 floor model Philco Has a 7A4 tube in place of one of the XXL tubes as called for in the schematic. It reads good on my tube tester but is it a proper replacement for the XXL or should I get another XXL ?
Thank You
Hi,
The 7A4 is a direct substitute for the XXL and should work fine. If you look up the XXL on tube suppliers websites they usually show XXL/7A4. Have several 7A4's in radios that work fine in place of the original XXL Philco tubes. John
You can check for good substitutions here:
http://www.nostalgiaair.org/Tubes/
Carl
Northern Panhandle, WV
Agreed. Some of these are microphonic, Just like the 6C5/6J5 that are the of the same family, sort of, but as an oscillater or IF amp, it shouldn't matter too much. Anyway no harm in trying. Switch 'em around for best performance.
[split] New member...
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
There are currently 1146 online users. [Complete List]
» 1 Member(s) | 1145 Guest(s)
