question about a Philco Tropical Model
Threads: 1
City: ATHENS
State, Province, Country: GREECE
Threads: 273
City: Wilsonville
State, Province, Country: OR
Threads: 273
City: Wilsonville
It would appear based on the fact that the turn table was made in England (assuming the turn table is original to the set) that the entire set was probably made there rather than in the US. Unfortunately we don't have much information on Philco Tropics made in England. Hopefully someone on the Phorum will be able to provide you with some additional information. If you had a photo of the back of the radio chassis, there is often a label or plate with model number information on it.
Threads: 32
City: Wellborn Florida
Voltage and Hertz would be right for Greece if it is a English made set. 1948-1950 time frame is when England starting using the wall outlet and plug they use today please post a picture of the plug on the power cord which should be 2 round pins for Greece. Welcome to the Phorum
If the unit still has its original back, it should have a model number printed on it. It will likely be four numbers, preceded by an A or a B - for example, A.1234 or B.2345.
If you can share this information with us, we might be able to track down something if it is available.
Unfortunately, service (and other) information for British-made Philco Tropic receivers is not always available anywhere, not even on the UK Vintage Radio Repair and Restoration forum.
Threads: 1
City: ATHENS
Thanks you so much for your welcome Ron and David! yes the unit still has its original back, and the model number printed on it is A. 3661. Its definitely made in Britain.
The plug on the power cord is not the original. The present has 2 round pins as the model has been in Athens, Greece since the early 50's (as far as we know). 1948-1950 time frame seems possible?
All the best,
Evangelos
Threads: 1
City: ATHENS
Thank you for your welcome to the Phorum Ron and David.
The unit still has its original back and the model number printed on it is A.3661. The original plug on the power cord does not exist anymore. The present has 2 round pins as the the unit was in use in Athens, Greece since the 1950's (as far as we know). 1948-1950 time frame seems possible?
All the best,
Evangelos
Thank you for furnishing the model number.
The UK Vintage Radio Repair and Restoration group issued a DVD filled with schematic diagrams and service information for many British-made radios. I have a copy of this DVD and I looked. Unfortunately, your model is not listed in this DVD set.
I am sorry I cannot help you further on this subject.
Threads: 118
City: Omak
State, Province, Country: WA
Hello Evangelos,
Welcome how exciting is this it is nice to see someone here from Greece !
Threads: 1
City: ATHENS
Thank you Ron, for your generous help! Hello Richard, greetings from Athens!
All the best,
Evangelos
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM |
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM |
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM |
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM |
Thank you.
I went to your online library and found 2 schematics.
I will download and compare to components!Ken D. — 06:31 PM |
It is a 16B tombstone.morzh — 06:13 PM |
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining.
The PSU...EdHolland — 06:06 PM |
Hi Everyone,
New member but have been reading this for awhile for tips!
Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM |
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM |
Hi DConant
Yes, you can replace chokes with resistors. You do stand the risk of increased hum. the solution is to inc...MrFixr55 — 04:23 PM |
There are currently 607 online users. [Complete List] » 1 Member(s) | 606 Guest(s)
