question about a Philco Tropical Model
Threads: 1
City: ATHENS
State, Province, Country: GREECE
Threads: 269
City: Bandon
State, Province, Country: OR
Threads: 269
City: Bandon
It would appear based on the fact that the turn table was made in England (assuming the turn table is original to the set) that the entire set was probably made there rather than in the US. Unfortunately we don't have much information on Philco Tropics made in England. Hopefully someone on the Phorum will be able to provide you with some additional information. If you had a photo of the back of the radio chassis, there is often a label or plate with model number information on it.
Threads: 23
City: Wellborn Florida
Voltage and Hertz would be right for Greece if it is a English made set. 1948-1950 time frame is when England starting using the wall outlet and plug they use today please post a picture of the plug on the power cord which should be 2 round pins for Greece. Welcome to the Phorum
If the unit still has its original back, it should have a model number printed on it. It will likely be four numbers, preceded by an A or a B - for example, A.1234 or B.2345.
If you can share this information with us, we might be able to track down something if it is available.
Unfortunately, service (and other) information for British-made Philco Tropic receivers is not always available anywhere, not even on the UK Vintage Radio Repair and Restoration forum.
Threads: 1
City: ATHENS
Thanks you so much for your welcome Ron and David! yes the unit still has its original back, and the model number printed on it is A. 3661. Its definitely made in Britain.
The plug on the power cord is not the original. The present has 2 round pins as the model has been in Athens, Greece since the early 50's (as far as we know). 1948-1950 time frame seems possible?
All the best,
Evangelos
Threads: 1
City: ATHENS
Thank you for your welcome to the Phorum Ron and David.
The unit still has its original back and the model number printed on it is A.3661. The original plug on the power cord does not exist anymore. The present has 2 round pins as the the unit was in use in Athens, Greece since the 1950's (as far as we know). 1948-1950 time frame seems possible?
All the best,
Evangelos
Thank you for furnishing the model number.
The UK Vintage Radio Repair and Restoration group issued a DVD filled with schematic diagrams and service information for many British-made radios. I have a copy of this DVD and I looked. Unfortunately, your model is not listed in this DVD set.
I am sorry I cannot help you further on this subject.
Threads: 92
City: Omak
State, Province, Country: WA
Hello Evangelos,
Welcome how exciting is this it is nice to see someone here from Greece !
Threads: 1
City: ATHENS
Thank you Ron, for your generous help! Hello Richard, greetings from Athens!
All the best,
Evangelos
Philco 46-480 Cabinet Restoration
Nice work! Take care and BE HEALTHY! GaryGarySP — 11:29 AM |
Thank you!jrblasde — 10:00 PM |
Philco Model 95 High Boy
So today I get published as I update my collection in the Radio Museum web site. I tried to published pictures of my Phi...slford310 — 08:00 PM |
Philco 84 antenna connection
Very simply connect al long piece of wire to that contact for your antenna. A piece 10 to plus 50 feet is no issue dep...slford310 — 07:46 PM |
I like it!Burchjburch — 05:57 PM |
I knew when I asked the question here, that I just wasn’t satisfied with the darkness of the stain. Today I took some mi...jrblasde — 04:54 PM |
I've used a single long wire up as high as possible and away obstacles. The gnd can be connected to a copper water pipe ...Radioroslyn — 03:34 PM |
Philco 51-632
Found this today for $10 in the local resale shop. It’s a violation of good procedure but I put it on the variac. It cam...bridkarl — 03:25 PM |
Philco 41-221 Restored
Rod
Great job, looks good, no need to refinish to my taste.
It is rare that you see the tenite grill in these in decent...morzh — 03:01 PM |
My last cabinet for this year
Beautiful Job!!!! Looks awsomeslford310 — 03:01 PM |
There are currently 2253 online users. [Complete List] » 1 Member(s) | 2252 Guest(s)
