Philco 650 same as a 660?
I am looking for a 37-650 chassis & speaker and someone has offered a restored 37-660 instead.
Does anyone know if the holes are the same.
 Kirk
One is 8-tube and 3-band, the other is 9-tube and 4-band.
They used the same cabinet for the tabletops. so the holes should be the same.
The 37-660 chassis will fit inside a 37-650 cabinet,
BUT...
You would need a different escutcheon with a larger opening.
The 37-650 is a three-band set while the 37-660 is a four band set. Larger dial scale, needing an escutcheon with a larger opening for the dial.
https://philcoradio.com/gallery2/1937a/#Model_37-650B
https://philcoradio.com/gallery2/1937a/#Model_37-660B
Thank you both!
Icon_smile
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
There are currently 608 online users. [Complete List]
» 1 Member(s) | 607 Guest(s)
