Magnavox 155B
ALL, i have 3 separate units that go with this
AMP-101A power supply and Amp
Cr-188 SW and BCST receiver
CR-206E FM convertor
I have the power supply hooked to receiver.. all seems to work correctly
But do not really know what antennas to hook up I have the loop antenna that goes with it..
There is connections for the loop and also an antenna..
Also a switch in chassis that says loop / antenna..
on convertor there are connections for a antenna and plug to the receiver. I have NO FM No noise at all.
Where to look?
Skip
OK started to try alignment.. IF's went well. but trying to adjust the bcst band .. the OSC trimmer has NO effect.
it receives well but . EX: station at 1440 khz comes in at just under 1200 on dial station at 1060 is about 950 khz .I can not get it to change..
SW seems to be very close..
any clues??? Has anyone aligned one of these??
Skip
Ok Found a bad trimmer cap for the Bcst band. replace it now able to align with no problem.. SO AM and SW now working very well..
Next Issue I have the FM Convertor. hooked it up and all I get is a bunch of crackles noise.. Like static crashes.. i can bearly hear the 10.7 mhz IF signal..when injected .. no signals hear anywhere..
Any clue to what this could be??
Skip
when you inject the 10.7 signal, how is that modulated? It has to be FM modulated to push through a tone. Also, just a note, if the trimmer cap has a bad mica, you can cut a new insulator from a piece of the stiff, clear plastic they use in a lot of packaging these days, just cut it the same size with the same hole in the right place. It will usually work OK.
Hi Skip,
If the converter is a tube type then it probably has a dual triode, one for the rf amplifier and one for the oscillator. In the few FM front ends I've worked on, that tube has been weak or bad. Even when a tube tester said it is good.
For those follow this saga at home here is the service info for the FM tuner: http://www.nostalgiaair.org/PagesByModel...010343.pdf
Rod
To answer your question it uses a 6SA7 on steroids for the mixer. (6SB7Y)
Found that the 6sb7y tube was bad. no filament.. i do not have any spares..
so need to order a few .. I did try a 6sa7 but that did not work either.. Tube was good but will not work in set
Skip
Like Terry said, you need to feed it some steroids. Glad you found the bad tube, it's a hopeful sign. Not too much to go wrong in that area.
Isolated to the Disc Coil I think..
[Image: https://live.staticflickr.com/65535/5219...4134_z.jpg]
[Image: https://live.staticflickr.com/65535/5219...24d4_z.jpg]
The caps are on bottom I think But what do I do next No clue as to values..
Skip
I looked at three schematics with FM discriminator circuits and two had 56pf and one had 60pf. I would suspect that there is a mica layer under the bottom with spring loaded contacts connected to the terminals. I've been successful in lifting a contract away far enough to render it inoperable then solder the replacement cap on the external terminals. When you bend the contact you are committed to using the external cap.
Ok so let's name the players. C-1 connects across the primary of the transformer. C-2 connects signal from the plate of the 6SB7Y to the secondary of the transformer. C-3 and C-4 create a capasitive tap to feed in signal into L-2. L-1 primary and L-2 secondary.
C-3 and C-4 are probably going to out of the equation as without C-1 or C-2 running afoul there wouldn't be any hv over there. C-1 is in parallel with L-1. It helps determines the resonate frequency along with the slug adjustment. It occurs to me that all four caps are part of that copper board cap and that all of it is going to go. C-3 and C-4 total are going equal about C-1 maybe 10-20mmf. C-2 is probably is going to be a bit smaller in value perhaps 5-10mmf. You may be able the measure them with a cap meter or check resonant frequency with GDO old skool...
ps Didn't see Rod's post so values are probably more realistic than my guesses.
Terry and Rob Ok thanks.. Terry I will send you a email.
Skip
Sent you an email in return.
Ok thanks to Radioroslyn who gave me a coil that would work.. I have to report all is Good now..Alignment went with no problems no noise.. lots of stations coming in.
Thank to all
Skip
So glad to hear you got it working!
Mr. Fixr Compared to you I am sooo green behibd the ears...I have about 40 or so sets.morzh — 07:12 PM
48-482 rear panel help
Many thanks to all for the responses! No plastic button "covers" on my radio. Ron, thanks for the chapter on...keithchip — 05:53 PM
I am back to working on this radio and managed to get a couple of radio stations to come in. But can someone help me to ...osanders0311 — 01:58 PM
Hi Kettlechip and welcom to the Phorum. The back panel question is interesting. I have quite a few radios that use pow...MrFixr55 — 08:24 AM
Not too much at all! :lol:  Sounds like you’re just dabbling into the hobby!jrblasde — 07:56 AM
Hi Joseph, Fortunately, Ms. Fixr does not read my computer, or she would warn you against coming to me for sanity ch...MrFixr55 — 07:27 AM
There's a picture of one of the plastic covers in the following thread: I bought a full set of them in 2012 or so fro...klondike98 — 11:15 PM
Good sanity check! You are correct—the first (as in, the most counterclockwise) position is for the push button presets....jrblasde — 11:05 PM
Hi Joseph, First, verify that your band selector is in the correct position for what you want to do. I believe tha...MrFixr55 — 10:59 PM
Got my replacement signal generator in the mail today! I was able to finish alignment of the IF section. I’ve got some t...jrblasde — 09:58 PM
There are currently 1030 online users. [Complete List]
» 2 Member(s) | 1028 Guest(s)
