Philco 630 - Static Noise Crackling.
The 630 I rehabbed was playing pretty good. Now it plays well on strong stations but a lot of static on weaker stations and while tuning between them, I probed around with a plastic alignment tool and notice that when I put some pressure on the 2nd IF transformer the Volume decreases and the static lessens. Is this what is known as Silver Mica disease?  The schematic does not document what size capacitors I have in the can. The transformer windings ohm out at 12 ohms. The transformer is a 32-1647. Any idea what size capacitors are in the can? If I ground out the antenna the noise is still there controlled with the volume. Am I correct assuming that the noise then is being generated inside the radio? On strong local stations it is still there but not as pronounced.
hello tludka,
These earlier sets did not have Mica problem
Well, I had the long wire antenna at about 15-foot height. I raised it to 20 feet and that cleaned up 95% of the noise problem.
Might be lighting static crashes you are hearing, they can be heard from long distance in the summer...
Simon
I find that interesting! So is the ant over something like a well pump or near the edge of roof. Glad it works. David
Have you cleaned your tuning cap?
Need Help to ID this radio 11 tube Philco
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
1.7-3.9 %, a modified Sine wave inverter is around 25%. Most generators from big box stores run 10% at a 50% load. What ...David — 04:06 PM
I am having a heck of a time doing the alignment on the AM band. I can't seem to dial in the 1500 KC oscillator. I can h...dconant — 03:35 PM
David - I think I understand but what units are you discussing (Low of 1.7, high of 3.9)? Budget constraints for Ham ...EdHolland — 01:43 PM
You're doing great. I wish I could be more involved, but my mind is right now preoccupied with the reason I am here in ...morzh — 12:21 PM
Hope you guys are still with me. I have moved on to the alignment. I completed the IF alignment which was pretty muc...dconant — 10:47 AM
There are currently 721 online users. [Complete List]
» 1 Member(s) | 720 Guest(s)
