Threads: 412
City: Boston
Picked this up at one of our swap meets in the spring.....very nice, 8 inch speaker, 9 tubes, excellent reception.
Dial was in good shape as well as pointer which is often broken on these, it has been cleaned up and plays very nice.
One of my better RCA's.
https://www.flickr.com/photos/92577012@N...300798953/
Threads: 114
City: Sneedville, TN
It reminds me of my parents' Zenith radio / record player. It had an AM radio and a 3 speed cobra-matic turntable. It was a table model like that with a mahogany cabinet. Nice find.
(This post was last modified: 07-24-2022, 10:20 PM by mikethedruid.)
Threads: 54
City: Lexington, KY
Nice looking set and I like the dial illumination.
Threads: 25
City: Wellborn Florida
Threads: 412
City: Boston
It sounds as good as any of the 50's era Zeniths which I also admire, there is a bakelit version too, see one buy it.
Threads: 147
City: Westland, MI
Great find, Paul. Take care and BE HEALTHY! Gary
Threads: 9
City: Greenlawn
State, Province, Country: NY
Have the 1R81 Livingston. Nice sound, blows the doors off the similar looking Zenith 7H820 AM FM that also has an 8" Speaker but hey, a 6V6 Power Amp running at 250V beats a 35B5 or 35C5 at 130V (the selenium rectifier yields higher B+ than a 35W4). However, Props to Zenith, as few sets using a 35B5 or 35C5 sound this nice.
FM doesn't work on mine yet. but AM is good and piping an Aux signal into the Amp of this radio yields a warm pleasing sound.
Changed all paper and 'lytic caps to no avail. I don't have a signal generator, so will have to play games with a working radio. 2 strange things about my radio are that the chassis is copper plated (RCA almost always used Cad plating in the 40s, 50, and 60s, and all the paper caps were PHILCO!!!???!!! (and these were originals).
Threads: 412
City: Boston
Odd, but you encounter many things in this hobby. Good luck with it.
Threads: 19
City: Cromwell
State, Province, Country: CT
Very nice looking radio! You can’t beat that vintage of AM/FM set for sound quality.
Tony
Threads: 412
City: Boston
It was find at the NEVEC meet, one of my better ones.
Threads: 412
City: Boston
I have been unable to take this one out of my listening room, anyone have any experience with these. Other than the 6V6 and the nice speaker is there any other reason this set sounds so good, general engineering, tube complement?
Could not find a schematic on Nostalgia air......
Threads: 4
City: washington nj
Hi Paul, Use schematic for 3RF91, which is the plastic version. Bill
Welcome Eric,
I agree with Bob and far as the two main electrolytic filter capacitors did you change them yourself or w...radiorich — 11:43 PM |
You mentioned the Philco manual and going through the check points...just to be sure we're on the same page here's the m...klondike98 — 08:13 PM |
Philco 42-1008 conversion kit
Interesting. I haven't seen that before.klondike98 — 07:02 PM |
12' Philco
Yes I had looked for it on the web as well some time back and could not find it. I was glad to see it turned up in Ron'...klondike98 — 06:59 PM |
Shadow Meter Bulb
Now if you had a set with a tuning light then the bulb type is important to the circuit, some sets used those prior to t...Arran — 04:58 PM |
Shadow Meter Bulb
Ok. Thanks for the correction.RossH — 03:09 PM |
Model 28L
For 28 you will probably need to buy a Hammond 125CSE. Or any of the series of the power you need, with SE suffix. Then ...morzh — 02:09 PM |
37-60 revision 6
I am restoring a Philco 37-60 and it shows run 6 they removed the ground from G3 of the 6K7G and put the G3 to -2.5v for...bobbyd1200 — 01:01 PM |
Shadow Meter Bulb
Mike is correct on the bulb connection, two separate circuits. I found that by rotating the bulb and sliding it forward ...RodB — 12:19 PM |
Hickok AC51 tube tester
Cleaned ann contacts, switches and sockets, works great now.martinj — 11:32 AM |
There are currently 3984 online users. [Complete List] » 3 Member(s) | 3981 Guest(s)
