Philco 89 Questions
It sounds like someone took some liberties with your radio.
Pin 4 of the 77 is the suppressor grid and should connect to ground.
Pin 5 of the 77 is the cathode and should connect to the top of the oscillator tickler coil per the schematic.
If I were you, I would change the wiring to correspond with the schematic.
Yes I will thank you Ron.......................
Jim
Spring Lake MI
Resolved the wiring on the #77 tube and it made a world of difference, can receive station across the dial. Will do an alignment, I am getting a lot of whistling and vibration in the speaker on certain frequency's. Hope the alignment will solve that.
Jim
Spring Lake MI
After an alignment I noticed that from about 1000 kHz and lower freq. the reception will work at times or not. Above 1000 kHz does not fail can always receive.
I had a VOM lead connected to chassis with meter on, with the other probe I would touch the #2 pin (plate) of #77 tube and make it (lower freq's) come and go. Also on the OSC coil I could touch pin #5 (to tuner) and it will cut out, touch pin #4 it will cut in, this is all to do with the lower freq's. If I touch pin #1 or pin#2 has no effect (tickler). Touching pin #3 will also make it cut out.
I don't know if this is a tube (#77) problem or the OSC coil or what.
I have a 6200 ohm resistor to ground instead of an 8000 ohm on the tickler coil.
I have rewound the tickler coil on the OCS coil it was open.
Jim
Spring Lake MI
Finally got this guy up and running. As I said it would work on high freq's and some times on lower freq's. I tried bonding all grounds, replace the OSC cathode resistor back to 8.2K no help. Finally I cleaned the 77 tube socket and replaced the 77 tube after cleaning the pin of the tube. WALA it now works, I am one happy camper.
Thanks for the help.
Jim
Spring Lake MI
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
