speaker replacement
I have a Wards 1942 Airline radio model 14BR-1109A. It has a 12 inch speaker that should be replaced. The only info I have is a P/N BE114261 T9. It is also marked 200ohms.
Does anyone know of a replacement?
Thanks.
So what did your P/N BE114261 T9 come out of? Is the original speaker missing?
Got your pm and if your could post a pic of the spkr and small tear it would be helpful. You will probably have to downsize the pics to meet the phorums size requirements.
Tnx
[attacGreetings,
Attached are photos of my Wards speaker. Any help would be greatly appreciatedhment=27349]         [Thanks,Mike                         attachment=27351]
I've seen worse. If the voice and field coils are good, a little rubber cement and tissue patches on the surround should fix it. Also a felt disk to protect the gap between the voice coil and magnet pole.
Agree 100%. Also, for what it's worth, it looks like a 1940 Philco speaker...
Thanks s to all of you! I will try your fix.
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
There are currently 539 online users. [Complete List]
» 1 Member(s) | 538 Guest(s)
