Philco 46-1226 Code 125
A customer brought me a model 46-1226 and I discovered it was a Code 125. The schematic was never drawn and the closest you can get is a Code 122. There are also several factory revision sheets which address factory changes to the 122. Hoping that someone on the forum can help. The owner pulled all of the tubes and put them in a bag. I cannot even start. The power supply is different since it uses a PM speaker. Please contact me if you can help.
Thank you,
The documentation in our library includes the code 125 power supply info you mentioned along with the changes that go with it. Does this help?
https://philcoradio.com/library/download...6-1947.pdf
Yes, this helps.
Thank you
Icon_thumbup
Need Help to ID this radio 11 tube Philco
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
1.7-3.9 %, a modified Sine wave inverter is around 25%. Most generators from big box stores run 10% at a 50% load. What ...David — 04:06 PM
I am having a heck of a time doing the alignment on the AM band. I can't seem to dial in the 1500 KC oscillator. I can h...dconant — 03:35 PM
David - I think I understand but what units are you discussing (Low of 1.7, high of 3.9)? Budget constraints for Ham ...EdHolland — 01:43 PM
You're doing great. I wish I could be more involved, but my mind is right now preoccupied with the reason I am here in ...morzh — 12:21 PM
Hope you guys are still with me. I have moved on to the alignment. I completed the IF alignment which was pretty muc...dconant — 10:47 AM
There are currently 699 online users. [Complete List]
» 1 Member(s) | 698 Guest(s)
