Philco 40-88 chassis wiring pictures
I could really use a picture of the chassis wiring for a 40-88. I’m having difficulty reading the schematic and I didn’t take pictures when I began replacing bare wires and especially from the on/off volume pot. Any reference pics or info would be appreciated.
Wicker Bill
This might have a clearer schematic:
https://worldradiohistory.com/Beitman-Manual.htm
Download the check mark for 1940 then scroll to page 80.
Or
I think they all come from the same place...
The power switch is pretty standard fair for a battery set. It disconnects the A+ and the B+. This insures no battery drain when the set is off.
Thanks, I was able to get a better schematic.
Mark
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
Refinishing Ideas
My 37-116 code 121 is the best sounding radio i have...a daily driver. Since we are talking about "changes". ...poulsbobill — 07:18 PM
Hello, I finally got brave enough to take the cans off the Expander Unit. Got the grid cap wires replaced and back toget...dconant — 06:50 PM
I got into the first AM IF can today, and found its mica was cracked. Amazing that it was still working. This one makes ...EdHolland — 06:10 PM
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
