Philco 90 Case Restore Question
I have been restoring a Philco 90, and it's almost back to running condition. It picks up stations, etc. but the volume control was dirty. It's been cleaned and it will be reconnected later today.  I have been "on again, off again" working on the case. I will be applying new veneer to both the grill cover, and the upper case. I'm not sure about what to use to darken the areas that have been routed around the grill and the outside edge. I'm really wanting the case to look really sharp. Any suggestions from those who have been here before?
Bob
I’ve used Miniwax Ebony wood stain for those areas on my 37-12. Not quite Black, but very a dark contrast to the Walnut finish.
Not sure if the 90 would have been treated differently, though.
mbhdesign
Michael Hennessey
Hi Bob,
That's a good question. If you google Philco 90 image  you will see all manner of shading on the cabinet. Original lacquer based finishes were used throughout. No oil based stains. In manufacturing lacquer is much fast drying than oil. And lacquer toners have a translucent look that stain doesn't.
After looking at the 90 in the gallery https://philcoradio.com/gallery2/1931b/#...Baby_Grand I would use ex dark brown for the trim (Mohawk M100-209) and columns. For the front panel  would use just a little M100-0207 medium brown. Would also use a coat sanding sealer beforehand.
GL w/your project!
I pulled the tube out and it's shorted from pin 1 to pin 2. I suppose that's the problem...sq65 — 08:12 AM
bob  Nice work on battery . If you don't. Have terminals i have a few spares  Samsam — 02:12 AM
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
schematics
Those filter caps in the cardboard tube are easy to restuff, especially the kind with the rolled over end. You don't hav...Arran — 09:56 PM
There are currently 2149 online users. [Complete List]
» 1 Member(s) | 2148 Guest(s)
