S-7 Speaker rebuild or replace
Hi everybody,
I’ve got a 37-60 with an S-7 speaker that needs help.
The field coil resistance tests well at 1197k ohms.
I’m not sure if I should try to rebuild this one, or seek a replacement. What do the wiser heads here have to say?
Thanks!
mbhdesign
Michael Hennessey
Contact Rich Stamer at Sound Remedy. Icon_thumbup
http://www.soundremedynj.com/
Ok, Ron! Thanks.
mbhdesign
Michael Hennessey
As longa s the FC is OK, which it seems to be, I agree with Ron.
And Rich is on the mend and has just done a beautiful job on my 16's 10" speaker.
Hello Michael ,
It sounds like you have this covered !
I just got done repairing a speaker this week for one my sets .
Thanks again, guys! Glad to have your experience and encouragement on this. Much appreciated as always!
mbhdesign
Michael Hennessey
David - I think I understand but what units are you discussing (Low of 1.7, high of 3.9)? Budget constraints for Ham ...EdHolland — 01:43 PM
My Philco 37-116 Restore
You're doing great. I wish I could be more involved, but my mind is right now preoccupied with the reason I am here in ...morzh — 12:21 PM
Hope you guys are still with me. I have moved on to the alignment. I completed the IF alignment which was pretty muc...dconant — 10:47 AM
Hello MrFixr55, Thank you for taking the time to explain. I measured 50 volts where you say. Today the 370 volts at ...dconant — 12:51 PM
Oh that sucks. It’s something easily overlooked. Hopefully it’s nothing more than a resistor! Ron462ron — 08:08 AM
Just confirmed that you are correct. It’s the function generator. I connected the signal output probe to one of the inpu...jrblasde — 07:52 AM
Ouch, you may be right. Yes, it is solid state. It’s the signal output of my oscilloscope. May be time to crack that ...jrblasde — 07:27 AM
If you didn’t put a DC blocking cap between the signal generator probe and the plate of the 1st IF it’s possible you ble...462ron — 07:07 AM
Hi DConnant, The reason why C127 is isolated from ground is because sets of this vintage did not have the center tap...MrFixr55 — 01:07 AM
The shield is on the 6H6. It was, in fact, a missing jumper to connect the main chassis ground to the RF chassis grou...jrblasde — 10:58 PM
There are currently 1028 online users. [Complete List]
» 2 Member(s) | 1026 Guest(s)
