Philco IF Transformers
Does anyone have a link or other documentation that lists the values of all the IF transformers used by Philco?  I'm trying to find other chassis' that used the same 2nd IF trans as was used in the model 52 since I'm having an issue with finding a junk mod 52 that i can strip.
Philco's: 86 Low Boy, 90 High Boy, 95 High Boy, 76 High Boy, 112X Console, 118X Console, 41-265 Console, 41-608P Console, 52GC, 370 LZ, 512, 20 Baby Grand, 70 Baby Grand, 71B, 52B, 118B, 60B, 84B, 610B, 37-89B, 38-10T, 38-35B, 41-221CI, 42-321T, 46-1203
48-214, 48-206, 49-506
If that is a 52 baby grand with 175 IF, you might try a 262KC IF Meissner or Miller (plentiful ebay) as they have a broad range to get you up and running until you find 175.
I don't recommend using a 260/262 kc IF transformer.
IF transformers from Philco models 111, 112, 90 (early and middle production), 51, and 52 all use 175 kc IF transformers. Model 17 does also; however, model 17 is less common.
Oh, and the documentation you asked for does not exist. I don't think anyone has compiled a list of all Philco IF transformers, their design frequencies, and the radios using them. However, the listing I gave you above covers all Philco home sets using a 175 kc IF.
David - I think I understand but what units are you discussing (Low of 1.7, high of 3.9)? Budget constraints for Ham ...EdHolland — 01:43 PM
My Philco 37-116 Restore
You're doing great. I wish I could be more involved, but my mind is right now preoccupied with the reason I am here in ...morzh — 12:21 PM
Hope you guys are still with me. I have moved on to the alignment. I completed the IF alignment which was pretty muc...dconant — 10:47 AM
Hello MrFixr55, Thank you for taking the time to explain. I measured 50 volts where you say. Today the 370 volts at ...dconant — 12:51 PM
Oh that sucks. It’s something easily overlooked. Hopefully it’s nothing more than a resistor! Ron462ron — 08:08 AM
Just confirmed that you are correct. It’s the function generator. I connected the signal output probe to one of the inpu...jrblasde — 07:52 AM
Ouch, you may be right. Yes, it is solid state. It’s the signal output of my oscilloscope. May be time to crack that ...jrblasde — 07:27 AM
If you didn’t put a DC blocking cap between the signal generator probe and the plate of the 1st IF it’s possible you ble...462ron — 07:07 AM
Hi DConnant, The reason why C127 is isolated from ground is because sets of this vintage did not have the center tap...MrFixr55 — 01:07 AM
The shield is on the 6H6. It was, in fact, a missing jumper to connect the main chassis ground to the RF chassis grou...jrblasde — 10:58 PM
There are currently 1022 online users. [Complete List]
» 2 Member(s) | 1020 Guest(s)
