Antennas
Hi guys. I've been MIA for a few years, moving house a couple times among other significant events keeping me from this hobby.
I listened to my Model 20 a fair amount during 2020 while working from home until the power stopped working. I finally had a look and discovered a poor original wire from the power switch. Replaced and it's back in business (except for an issue of occasional good signal that becomes poor and drops as the set warms up over a couple minutes. My original thought was a hot tube issue, but will start looking into it more this spring).
Now that I'm settled in a house, I'm thinking of improved reception for my radios. What do you guys think of a roof aerial or something mounted in the attic? I've used an assortment of plain wire antennas over the years that have been "ok", but would like better performance overall. I'm about 30 miles southwest of Chicago and can pick up a couple stations pretty well, but not much else. I'd like to listen to something besides the ballgame and political talk radio.
Greg
Quote:I'm thinking of improved reception for my radios. What do you guys think of a roof aerial or something mounted in the attic?
Good idea Icon_biggrin
Give it a good ground too, short and direct to earth, not the ground for the wall outlet...
Chas
Pliny the younger
Quote:Give it a good ground too, short and direct to earth, not the ground for the wall outlet...
I figured I'd run a long wire to the basement and ground it to the water main from the city. It's copper and certainly underground!
Greg
Hi Greg, as for an antenna, I’ve had great results using my landline phone line. In most homes, there are 4 wires in the line coming in. 2 of them are fore the phone and the other 2 have nothing on them. I hooked a .001mfd cap to either one of those and run a wire to my radio. That gets me about 60’ or more of antenna running from the house, up high and out to the pole on the street plus the extra footage run throughout the house. And now since we’ve done away with our home phone, I can put my radio in any room in the house and have access to that antenna from any phone Jack.
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
My Philco 37-116 Restore
Hi DConnant, The reason why C127 is isolated from ground is because sets of this vintage did not have the center tap...MrFixr55 — 01:07 AM
The shield is on the 6H6. It was, in fact, a missing jumper to connect the main chassis ground to the RF chassis grou...jrblasde — 10:58 PM
When dealing with noise on power lines, time to get my Jackery 240 out. Talk about clean can hold a portable am radio ne...David — 08:52 PM
Arran - I bet you're right probably vinyl, there was no rubber smell when desoldering it, which you often get with the o...EdHolland — 08:23 PM
Ed; It was very likely vinyl covered wire given the vintage of the set, there was some rubber/gutta percha wire used ...Arran — 06:34 PM
I think the problem is traced - to noise on the AC line. It sounded so local, that it seemed certain it was generated wi...EdHolland — 05:51 PM
A little bit of positivity in our feed... My new video... Test - the Philco 16B vs Philco 37-116 de Luxe / Test - the ...RadioSvit — 12:14 PM
Refinishing Ideas
Thanks. I will look into. Billpoulsbobill — 11:23 AM
Why do the flood lights have 2 wires running to the shell of each light when the inner conductor only has one to each? ...dconant — 10:54 AM
OOPS!! if there is a "flag" running up the side of the tube that touches the shield, then yes, a shield belon...MrFixr55 — 10:03 AM
